Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓Prerequisite only guide to removing the e-liquid tank from the vape.
Grasp the mouthpiece with a pair of pliers.
Give it a good, solid twist, left or right doesn't matter.
If the mouthpiece seal came off with the mouthpiece, good, because you'll need to take it off anyway.
Use your tweezers to take out the seal and set it aside.
The rim around the top goes toward the mouthpiece.
Note that the mouthpiece has a tab that only allows it to be mounted in one orientation. The arrow here points to the one you'll need to match up with on the case.
Here you can see inside the case where the tab on the mouthpiece lines up.
Turn the power switch to the Off position; no air holes should be visible.
Use your opening tool to lever the power button up. It is only pressed on; there are no adhesives or clips to deal with.
Remove the power button.
The rear cover (the colored part) is clipped on, but the clips are tricky to undo. Start with the top edge and pry it up with your metal opening tool.
In the gap you can now see on the side, slip in an opening pick to keep it open.
Insert an opening pick in one side of the front cover to disengage the two latching tabs on that side.
Insert it far enough to be seen through the rectangular cutouts for the tabs.
Use the point of a spudger to flip up the retaining latch on the display's circuit board.
Start by inserting your pry tool in the bottom seam on one side. Separate the housing slightly.
Flip the vape over and pop the other side loose.
Peel off the Kapton tape securing the battery to the fluid tank.
With the battery freed, the tank can now be separated from the battery and circuit board.
Locate the seam between the tank seal and the lower case seal.
Separate the two seals.
