Up to 20% off select tools
OVNS Firework Tank Cover Removal
View statistics:
Past 24 Hours:
0
Past 7 Days:
Past 30 Days:
12
All Time:
32
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Easy
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
This is a prerequisite only guide showing how to remove the tank cover.
    1. OVNS Firework Tank Cover Removal, Remove the Mouthpiece: step 1, image 1 of 2 OVNS Firework Tank Cover Removal, Remove the Mouthpiece: step 1, image 2 of 2
      • Grasp the mouthpiece with a pair of pliers.
      • Give it a good, solid twist, left or right doesn't matter.
      • The pliers won't damage the silicone coating on the mouthpiece, but faint marks may be visible.
      Ask FixBot
    2. OVNS Firework Tank Cover Removal, The Mouthpiece Seal: step 2, image 1 of 3 OVNS Firework Tank Cover Removal, The Mouthpiece Seal: step 2, image 2 of 3 OVNS Firework Tank Cover Removal, The Mouthpiece Seal: step 2, image 3 of 3
      • If the mouthpiece seal came off with the mouthpiece, good, because you'll need to take it off anyway.
      • Use your tweezers to take out the seal and set it aside.
      • The rim around the top goes toward the mouthpiece.
      Ask FixBot
    3. OVNS Firework Tank Cover Removal, Replacing the Mouthpiece: step 3, image 1 of 2 OVNS Firework Tank Cover Removal, Replacing the Mouthpiece: step 3, image 2 of 2
      • Note that the mouthpiece has a tab that only allows it to be mounted in one orientation. The arrow here points to the one you'll need to match up with on the case.
      • Here you can see inside the case where the tab on the mouthpiece lines up.
      Ask FixBot
    4. OVNS Firework Tank Cover Removal, Remove the Power Button: step 4, image 1 of 3 OVNS Firework Tank Cover Removal, Remove the Power Button: step 4, image 2 of 3 OVNS Firework Tank Cover Removal, Remove the Power Button: step 4, image 3 of 3
      • Turn the power switch to the Off position; no air holes should be visible.
      • Use your opening tool to lever the power button up. It is only pressed on; there are no adhesives or clips to deal with.
      • Remove the power button.
      Ask FixBot
    5. OVNS Firework Tank Cover Removal, Remove the rear cover: step 5, image 1 of 2 OVNS Firework Tank Cover Removal, Remove the rear cover: step 5, image 2 of 2
      • The rear cover (the colored part) is clipped on, but the clips are tricky to undo. Start with the top edge and pry it up with your metal opening tool.
      • In the gap you can now see on the side, slip in an opening pick to keep it open.
      Ask FixBot
    6. OVNS Firework Tank Cover Removal: step 6, image 1 of 2 OVNS Firework Tank Cover Removal: step 6, image 2 of 2
      • Now repeat the previous step on the bottom corner of the cover.
      Ask FixBot
    7. OVNS Firework Tank Cover Removal: step 7, image 1 of 2 OVNS Firework Tank Cover Removal: step 7, image 2 of 2
      • Flip the vape over and pry up the bottom corner of the cover.
      • Add an opening pick.
      Ask FixBot
    8. OVNS Firework Tank Cover Removal: step 8, image 1 of 2 OVNS Firework Tank Cover Removal: step 8, image 2 of 2
      • Finally, the upper corner gets the same treatment.
      • Aaand, one final pick.
      Ask FixBot
    9. OVNS Firework Tank Cover Removal: step 9, image 1 of 2 OVNS Firework Tank Cover Removal: step 9, image 2 of 2
      • There are also internal clips along the rear side that are still holding the cover in place. It just takes a bit of force to pop it off. Grasp the long edge of the cover and pull hard.
      • With that, the cover is off.
      Ask FixBot
    10. OVNS Firework Tank Cover Removal, Remove the front cover: step 10, image 1 of 2 OVNS Firework Tank Cover Removal, Remove the front cover: step 10, image 2 of 2
      • Insert an opening pick in one side of the front cover to disengage the two latching tabs on that side.
      • Insert it far enough to be seen through the rectangular cutouts for the tabs.
      Ask FixBot
    11. OVNS Firework Tank Cover Removal: step 11, image 1 of 3 OVNS Firework Tank Cover Removal: step 11, image 2 of 3 OVNS Firework Tank Cover Removal: step 11, image 3 of 3
      • On the other side, insert your pry tool.
      • Lever the tool up to both free the tabs and slide the vape out of the front cover.
      Ask FixBot
    12. OVNS Firework Tank Cover Removal: step 12, image 1 of 1
      • The front cover has been removed.
      Ask FixBot
    13. OVNS Firework Tank Cover Removal, Disconnect the display ribbon cable: step 13, image 1 of 2 OVNS Firework Tank Cover Removal, Disconnect the display ribbon cable: step 13, image 2 of 2
      • Use the point of a spudger to flip up the retaining latch on the display's circuit board.
      Ask FixBot
    14. OVNS Firework Tank Cover Removal: step 14, image 1 of 2 OVNS Firework Tank Cover Removal: step 14, image 2 of 2
      • Unplug the ribbon cable with a pair of tweezers.
      Ask FixBot
    15. OVNS Firework Tank Cover Removal, Remove the housing: step 15, image 1 of 2 OVNS Firework Tank Cover Removal, Remove the housing: step 15, image 2 of 2
      • Start by inserting your pry tool in the bottom seam on one side. Separate the housing slightly.
      • Flip the vape over and pop the other side loose.
      • Do not attempt to pull the vape out of the top housing; the tank is only secured by the battery wires and you may damage them if you try. The next page will show you how to remove it.
      Ask FixBot
    16. OVNS Firework Tank Cover Removal: step 16, image 1 of 3 OVNS Firework Tank Cover Removal: step 16, image 2 of 3 OVNS Firework Tank Cover Removal: step 16, image 3 of 3
      • Holding the vape upright, push the tank out of the cover. Locate the white absorbent pad visible in the air passage.
      • Press down on the pad.
      • Once enough of the tank is exposed, you can grasp that and pull the tank/battery/electronics assembly out.
      Ask FixBot
    17. OVNS Firework Tank Cover Removal: step 17, image 1 of 1
      • The tank cover has been removed.
      Ask FixBot
Author
with
Jerry Wheeler
103,436 Reputation
97 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 32
