ORFELD EV-660-S222 Filter Replacement
Views: 2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
102
All Time:
1,990
Comments: 2
2 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
If your ORFELD EV660’s filters are dirty and need replacement this is the guide for you. In this guide we will walk you through the whole process of accessing the filters and replacing them. Clean filters are essential for a vacuum to work efficiently. So, if you notice your vacuum making a lot of noise or lacking suction then it might be because your filter is clogged and needs replacement. This is a beginner friendly guide as its quick and won't require any special equipment.
    1. ORFELD EV-660-S222 Filter Replacement, Filter: step 1, image 1 of 1
      • Separate the dust cover and the motor from the vacuum body by pressing the eject button.
      Ask FixBot
    2. ORFELD EV-660-S222 Filter Replacement: step 2, image 1 of 3 ORFELD EV-660-S222 Filter Replacement: step 2, image 2 of 3 ORFELD EV-660-S222 Filter Replacement: step 2, image 3 of 3
      • Remove the filter component from the dust cup.
      Ask FixBot
    3. ORFELD EV-660-S222 Filter Replacement: step 3, image 1 of 3 ORFELD EV-660-S222 Filter Replacement: step 3, image 2 of 3 ORFELD EV-660-S222 Filter Replacement: step 3, image 3 of 3
      • Remove the dust filter cover by twisting it out.
      Ask FixBot
2 other people completed this guide.
2 Guide Comments
Where can I get replacement filters for this model?
Lucy - Reply Share
I have the same question. Where can I get replacemet filters for this model? It doesn't seem like they are made anymore and the filter is attached to the rubber sealed part it is not round in shape.
Steve and Jody Brown - Reply Share
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 102
All Time: 1,990
