OPPO N1 Home Button, Volume Buttons and SIM Card Tray Replacement
  1. OPPO N1 Home Button, Volume Buttons and SIM Card Tray Replacement, Rear Case: step 1, image 1 of 1
    • Insert the plastic opening tool into the crevice. The back cover is most easily opened by starting at this location.
  2. OPPO N1 Home Button, Volume Buttons and SIM Card Tray Replacement: step 2, image 1 of 2 OPPO N1 Home Button, Volume Buttons and SIM Card Tray Replacement: step 2, image 2 of 2
    • In the photo we rotated the phone ninety degrees counterclockwise.
    • Gently slide the plastic opening tool around the edge of the phone to release the back cover from the phone. You may hear some snapping noises as you release the back cover.
    • The rear case should then come free.
  3. OPPO N1 Home Button, Volume Buttons and SIM Card Tray Replacement, Home Button, Volume Buttons and SIM Card Tray: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers to remove the home button.
  4. OPPO N1 Home Button, Volume Buttons and SIM Card Tray Replacement: step 4, image 1 of 1
    • Use tweezers to remove the volume button.
  5. OPPO N1 Home Button, Volume Buttons and SIM Card Tray Replacement: step 5, image 1 of 2 OPPO N1 Home Button, Volume Buttons and SIM Card Tray Replacement: step 5, image 2 of 2
    • In the first photo we rotated the phone 180 degrees. Use tweezers to remove the SIM card tray.
    • The phone has been rotated in the second picture to show where the buttons are removed from.
    • Our home button is not the original home button and is a replacement piece.
4 other people completed this guide.
Joshua Stone
1,067 Reputation
5 Guides authored
USF Tampa, Team 13-5, Staggers Fall 2014 Member of USF Tampa, Team 13-5, Staggers Fall 2014
USFT-STAGGERS-F14S13G5
3 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 2,668
