Installing OLPC XO-4 Touch Keyboard
  1. Installing OLPC XO-4 Touch Keyboard, Battery: step 1, image 1 of 1
    • Turn the laptop upside-down, with the handle facing away from you.
  2. Installing OLPC XO-4 Touch Keyboard: step 2, image 1 of 2 Installing OLPC XO-4 Touch Keyboard: step 2, image 2 of 2
    • Pull the lock tabs towards the green outer edges of the laptop.
    • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
  3. Installing OLPC XO-4 Touch Keyboard: step 3, image 1 of 2 Installing OLPC XO-4 Touch Keyboard: step 3, image 2 of 2
    • Lift up on the middle of the battery to remove it from the device.
  4. Installing OLPC XO-4 Touch Keyboard, Keyboard: step 4, image 1 of 2 Installing OLPC XO-4 Touch Keyboard, Keyboard: step 4, image 2 of 2
    • Remove the two 2mm Phillips #1 screws from beneath the battery lock tabs.
  5. Installing OLPC XO-4 Touch Keyboard: step 5, image 1 of 3 Installing OLPC XO-4 Touch Keyboard: step 5, image 2 of 3 Installing OLPC XO-4 Touch Keyboard: step 5, image 3 of 3
    • Flip the laptop over to its normal position.
    • Lift the two antennas on both sides to unlock the screen.
    • Open the laptop.
  6. Installing OLPC XO-4 Touch Keyboard: step 6, image 1 of 2 Installing OLPC XO-4 Touch Keyboard: step 6, image 2 of 2
    • Be careful not to pull the keyboard too far because there is still a ribbon cable attached to the bottom.
    • Gently lift up on the back of the keyboard.
    • Pull the keyboard up far enough to expose the ribbon cable.
  7. Installing OLPC XO-4 Touch Keyboard: step 7, image 1 of 2 Installing OLPC XO-4 Touch Keyboard: step 7, image 2 of 2
    • Gently lift up on the black connector to release the ribbon cable.
    • Gently pull the blue plastic tab up and away from the black connector.
    • Remove the keyboard from the laptop.
Michael Kellerman
58 Reputation
3 Guides authored
Cal Poly, Team 3-30, Amido Winter 2013 Member of Cal Poly, Team 3-30, Amido Winter 2013
CPSU-AMIDO-W13S3G30
3 Members
12 Guides authored
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 18
All Time: 899
