Starting at the Micro SD Card Slot and using the blue plastic opening tool, begin to maneuver the tool around the edges while applying light pressure to lift the panel upwards.
Tool used on this step:Tweezers$4.99
Use the angled tweezers to disconnect the black power cable from the mother board. The Cable should pop up from its slot when pulled.
You do not need to disconnect the antenna power cable. You only need to disconnect the other 2 black power cables. Just pull the antenna out together with the Mboard.
Did you not remove the battery and disoldered its cables? Why are they still in place?
Using the angled tweezers, begin removing the antenna from the device.
You only need to free the antenna from the case. Leave it hanging from the Mboard.
3 other people completed this guide.
One Comment
Odd question for you. I'm replacing the antena in a nvidia shield as an experimant, as was wonder if you know what type of connecter is used on the cable to the pcb. I dont want to desoder the exsisting antenna if i can help it as they are calabrated.
