Nvidia Shield Tablet Rear Case Replacement
  1. Nvidia Shield Tablet Rear Case Replacement, Rear Case: step 1, image 1 of 2 Nvidia Shield Tablet Rear Case Replacement, Rear Case: step 1, image 2 of 2
    • First, remove the stylus from your tablet.
  2. Nvidia Shield Tablet Rear Case Replacement: step 2, image 1 of 3 Nvidia Shield Tablet Rear Case Replacement: step 2, image 2 of 3 Nvidia Shield Tablet Rear Case Replacement: step 2, image 3 of 3
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
    • Set the tablet so the buttons, microSD, and stylus port are facing you.
    • Open the microSD slot.
    • Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
    • You may want to put on your anti-static wrist strap at this point as the motherboard will be vulnerable to physical touch and electrostatic shock after the casing is removed.
  3. Nvidia Shield Tablet Rear Case Replacement: step 3, image 1 of 2 Nvidia Shield Tablet Rear Case Replacement: step 3, image 2 of 2
    • As you remove your case, be aware of small clips along the edges.
    • Finally, set the old casing aside.
5 other people completed this guide.
Molly Bauer
1,478 Reputation
6 Guides authored
USF Tampa, Team 2-2, Blackwell Fall 2015 Member of USF Tampa, Team 2-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G2
3 Members
11 Guides authored
1 Guide Comment
I snapped the cable of the dabbler on the rear case coz i didnt know there was one!
Anyone knows where can i get a new one?
damjannedelkovski - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 3,544
