NVIDIA SHIELD Portable Motherboard Replacement
  1. NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: step 1, image 1 of 3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: step 1, image 2 of 3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: step 1, image 3 of 3
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
  2. NVIDIA SHIELD Portable Motherboard Replacement, Remove Green Grill: step 2, image 1 of 2 NVIDIA SHIELD Portable Motherboard Replacement, Remove Green Grill: step 2, image 2 of 2
    • The green grill is not screwed in so it can be pulled right out.
  3. NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: step 3, image 1 of 3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: step 3, image 2 of 3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: step 3, image 3 of 3
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Apparatus: step 4, image 1 of 1
    • Pull the battery apparatus out once all cables are removed.
  5. NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: step 5, image 1 of 3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: step 5, image 2 of 3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: step 5, image 3 of 3
    • Cooling is important for electronics, the last thing they want is to overheat.
    • Remove the two 7.3mm and four 8.4mm T5 Torx screws and disconnect the power cable.
    • Lift the fan free after the screws and cable are removed.
  6. NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: step 6, image 1 of 3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: step 6, image 2 of 3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: step 6, image 3 of 3
    • The large board under the back case is the motherboard.
    • Using your T5 Torx screwdriver, remove six screws from the motherboard—two 7.3 mm screws and four 8.4 mm screws.
    • Simply pull gently on the edges of the board, wiggling it if necessary so as not to damage the ports at the top of the board.
3 other people completed this guide.
Marc Perez
545 Reputation
2 Guides authored
USF Tampa, Team 1-1, Hickman Fall 2014 Member of USF Tampa, Team 1-1, Hickman Fall 2014
USFT-HICKMAN-F14S1G1
4 Members
18 Guides authored
One Comment
Hay ich suche Ersatzteile für Nvidia shield Portable ich suche Board da wo kühler drauf ist , weil mein ist kaput gegangen :(
Konstantin Styngu - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 1,815
