Nutri Ninja Ninja Blender Duo BL641 Body Disassembly
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Nutri Ninja Ninja Blender Duo BL641 Body Disassembly: step 2, image 1 of 2 Nutri Ninja Ninja Blender Duo BL641 Body Disassembly: step 2, image 2 of 2
    • Remove these six screws (0.5 inch 5 gauge phillip's head)
    • Note: 2 of the screws will be star shaped circled in blue
    • Lift the bottom panel off
  2. Nutri Ninja Ninja Blender Duo BL641 Body Disassembly: step 3, image 1 of 1
    • Unscrew and remove these six phillip's screws. (0.5 inch 5 gauge phillips)
    • Note: The screws circled in blue are 1/8" longer and have a slightly different top than the rest. These are the only two screws that are different than the rest.
  3. Nutri Ninja Ninja Blender Duo BL641 Body Disassembly: step 4, image 1 of 3 Nutri Ninja Ninja Blender Duo BL641 Body Disassembly: step 4, image 2 of 3 Nutri Ninja Ninja Blender Duo BL641 Body Disassembly: step 4, image 3 of 3
    • Insert pry tool in between the two plastic pieces to separate them
    • Move pry tool back and forth from right to left until the two pieces begin to separate as shown.
    • Pry the two pieces apart with your hands as shown in the picture to finish separating the pieces.
  4. Nutri Ninja Ninja Blender Duo BL641 Body Disassembly: step 5, image 1 of 1
    • This completes the disassembly of the main body of the blender so you can continue to perform replacements on the internal parts.
Nathan
201 Reputation
2 Guides authored
Cal Poly, Team S7-G1, Banghart Fall 2017 Member of Cal Poly, Team S7-G1, Banghart Fall 2017
CPSU-BANGHART-F17S7G1
5 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 47
