NuVision TM800A510L Rear Camera Replacement
    1. NuVision TM800A510L Rear Camera Replacement, Rear Camera: step 1, image 1 of 2 NuVision TM800A510L Rear Camera Replacement, Rear Camera: step 1, image 2 of 2
      • Use a Heat Gun to heat the sides of the device one at a time. The Heat Gun will loosen the adhesive.
      • Use thin tools to pry the back of the device off.
      • Metal tools may work best but may also scratch the device. Plastic prying tools can also be used.
      • Be careful around the power and volume buttons.
      Ask FixBot
    2. NuVision TM800A510L Rear Camera Replacement: step 2, image 1 of 1
      • There are two different cameras and each have different ribbons.
      • Unlock both ribbons by flipping the black bar up.
      Ask FixBot
    3. NuVision TM800A510L Rear Camera Replacement: step 3, image 1 of 2 NuVision TM800A510L Rear Camera Replacement: step 3, image 2 of 2
      • The camera facing towards the table lifts out easily, so go ahead and take that one out.
      • This works out well, if this is the camera you are most concerned about.
      • If you are more concerned the one facing you, move on to the next step.
      Ask FixBot
    4. NuVision TM800A510L Rear Camera Replacement: step 4, image 1 of 2 NuVision TM800A510L Rear Camera Replacement: step 4, image 2 of 2
      • This camera is held down with adhesive, so you must be careful when prying it.
      • GO SLOW!
      • Camera pulls up and out of its slot easily.
      Ask FixBot
Be advised that you will need to replace the adhesive.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 93
All Time: 820
