Novatel MiFi 2200 Circuit Board Replacement
  1. Novatel MiFi 2200 Circuit Board Replacement, Battery: step 1, image 1 of 1
    • Remove the rear cover by pressing down on the cover and pulling it away from the device.
  2. Novatel MiFi 2200 Circuit Board Replacement: step 2, image 1 of 1
    • Place your finger on the back of the battery located near the edge of the device.
    • Push your finger into the battery and lift up to pop the battery out of the device.
  3. Novatel MiFi 2200 Circuit Board Replacement, Case: step 3, image 1 of 1
    • Using a metal spudger, pry open the device around the seam between the front and back cover.
    • It may be difficult to split apart, so use force with caution.
    • It may seem like you are breaking the device, but you will only be breaking the adhesive lining that keeps the device sealed.
  4. Novatel MiFi 2200 Circuit Board Replacement: step 4, image 1 of 1
    • Once the seal has been broken all the way around, open the cases using your hands.
  5. Novatel MiFi 2200 Circuit Board Replacement, Circuit Board: step 5, image 1 of 1
    • To disconnect the antenna, pull up on the antenna's connection to the circuit board until it pops off.
  6. Novatel MiFi 2200 Circuit Board Replacement: step 6, image 1 of 1
    • Simply pick up the circuit board with your fingers and remove it from the case.
  7. Novatel MiFi 2200 Circuit Board Replacement: step 7, image 1 of 3 Novatel MiFi 2200 Circuit Board Replacement: step 7, image 2 of 3 Novatel MiFi 2200 Circuit Board Replacement: step 7, image 3 of 3
    • Apply double-sided stick tape to the inner top and bottom halves of the device along the seam that was previously unsealed.
    • Snap the two halves together along the adhesive line to reconnect it as it previously was.
After the circuit board is replaced the device should function properly again. When reassembling the device, keep in mind that you will need adhesive to keep the device together.
6 other people completed this guide.
Justin Russo
196 Reputation
3 Guides authored
Cal Poly, Team 7-36, Maness Spring 2012 Member of Cal Poly, Team 7-36, Maness Spring 2012
CPSU-MANESS-S12S7G36
5 Members
5 Guides authored
3 Guide Comments
Hello, where do you purchase the new circuit board?
David - Reply
I've tried every thing to get this device to work properly. Sic results. Sic.
Clennis Jones - Reply
Where and how can I get this thing replaced?
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 12
All Time: 2,319
