This teardown is not a repair guide. To repair your NovaStar Gasmelder, use our service manual.
    1. NovaStar Gas Detector, Opening the housing: step 1, image 1 of 2 NovaStar Gas Detector, Opening the housing: step 1, image 2 of 2
      • Remove the 4 screws on the back using a PH2 screwdriver
      • Lift off the housing
      Ask FixBot
    2. NovaStar Gas Detector, Remove the PCB: step 2, image 1 of 2 NovaStar Gas Detector, Remove the PCB: step 2, image 2 of 2
      • Remove the PCB
      Ask FixBot
    3. NovaStar Gas Detector, Components: step 3, image 1 of 3 NovaStar Gas Detector, Components: step 3, image 2 of 3 NovaStar Gas Detector, Components: step 3, image 3 of 3
      • Shown here is a small transformer, a rectifier with 4 diodes, a capacitor, and an LM7805 voltage regulator.
      • The circuit consists of an MQ-5 gas sensor, CMOS 4011, NE555 timer, LM358 comparator, a button, a piezo speaker, a potentiometer, resistors, and capacitors. That's it.
      • The gas sensor presumably needs to be heated, which is why the circuit board is discolored.
      • If the connector weren't severely bent and the threaded pieces broken, the gas detector would certainly still have worked.
      Ask FixBot
Ee_Es
934 Reputation
6 Guides authored
German Translators Member of German Translators
Community
51 Members
6,559 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 238
