Nostalgia GCM200 Power Cable Replacement
  1. Nostalgia GCM200 Power Cable Replacement, Nostalgia GCM200 Disassembly: step 1, image 1 of 2 Nostalgia GCM200 Power Cable Replacement, Nostalgia GCM200 Disassembly: step 1, image 2 of 2
    • Remove the two 1.3 mm Phillips #2 screws.
    • Remove the S6 spanner screw.
    • Carefully place these three screws somewhere safe to use later in reassembly.
  2. Nostalgia GCM200 Power Cable Replacement: step 2, image 1 of 1
    • Split the device in half to expose the internal parts of the device.
    • Again, there are two more Phillips screws to remove.
  3. Nostalgia GCM200 Power Cable Replacement: step 3, image 1 of 1
    • Remove the two screws from both sides of the heating coil.
  4. Nostalgia GCM200 Power Cable Replacement, Power Cable: step 4, image 1 of 1
    • Remove (flexible) plastic sleeves from the inside end of the power cable.
    • You might want to use force, pull out while shaking it.
Praful Busa
267 Reputation
2 Guides authored
UW Tacoma, Team S1-G4, Liner Summer 2017 Member of UW Tacoma, Team S1-G4, Liner Summer 2017
UWT-LINER-SU17S1G4
4 Members
5 Guides authored
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 10
All Time: 250
