Nook HD+ Top Frame Replacement
  1. Nook HD+ Top Frame Replacement, Removing Top Frame: step 1, image 1 of 3 Nook HD+ Top Frame Replacement, Removing Top Frame: step 1, image 2 of 3 Nook HD+ Top Frame Replacement, Removing Top Frame: step 1, image 3 of 3
    • Wedge the plastic opening tool underneath the frame at the bottom left hand corner of the Nook HD+ and begin prying open the front frame.
    • Note there will be glue and be careful not to break the clips.
  2. Nook HD+ Top Frame Replacement, Add New Glue: step 2, image 1 of 1
    • Apply glue round the inside perimeter of the new frame on the clip side.
  3. Nook HD+ Top Frame Replacement: step 3, image 1 of 1
    • Line up the new frame with the bottom left hand edge of the frame lined up with the hole on the center chaise push down on the frame until all the clips pop back into the slot the belong.
    • Run finger around the entire frame making sure all the clips are in place.
    • Let glue dry.
Alex Pelicas
283 Reputation
2 Guides authored
UMass Dartmouth, Team 2-3, Duarte Fall 2014 Member of UMass Dartmouth, Team 2-3, Duarte Fall 2014
UMASSD-DUARTE-F14S2G3
5 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 810
