Shop the Holiday Gift Guide
Nook Color Front Cover Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
0
Past 30 Days:
4
All Time:
193
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
    1. Nook Color Front Cover Replacement, Back Cover: step 1, image 1 of 2 Nook Color Front Cover Replacement, Back Cover: step 1, image 2 of 2
      • Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
      Ask FixBot
    2. Nook Color Front Cover Replacement: step 2, image 1 of 2 Nook Color Front Cover Replacement: step 2, image 2 of 2
      • Pry off the back cover with the plastic opening tool. Go around the device with the tool to ensure complete detachment.
      Ask FixBot
    1. Nook Color Front Cover Replacement, Front Cover: step 3, image 1 of 1
      • Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
      Ask FixBot
    2. Nook Color Front Cover Replacement: step 4, image 1 of 2 Nook Color Front Cover Replacement: step 4, image 2 of 2
      • Pry off the front panel using the plastic opening tool.
      Ask FixBot
    3. Nook Color Front Cover Replacement: step 5, image 1 of 2 Nook Color Front Cover Replacement: step 5, image 2 of 2
      • Lift up on the connectors to disconnect them using the plastic opening tool.
      Ask FixBot
Author
with
Matthew Perdomo
536 Reputation
3 Guides authored
USF Tampa, Team 11-5, Blackwell Winter 2015 Member of USF Tampa, Team 11-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G5
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 193
