Nokia Lumia 930 Camera Replacement
    1. Nokia Lumia 930 Camera Replacement, Battery: step 1, image 1 of 1
      • Pull the SIM card holder out of the top of the phone using your fingernail.
      Ask FixBot
    2. Nokia Lumia 930 Camera Replacement: step 2, image 1 of 2 Nokia Lumia 930 Camera Replacement: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Place tweezers or an opening tool in the SIM card slot and push upwards until the back panel pops out.
      Ask FixBot
    3. Nokia Lumia 930 Camera Replacement: step 3, image 1 of 2 Nokia Lumia 930 Camera Replacement: step 3, image 2 of 2
      • Wedge a plastic opening tool between the two panels. Slide it along each side of the phone to completely remove the back panel.
      Ask FixBot
    4. Nokia Lumia 930 Camera Replacement: step 4, image 1 of 1
      • Remove the 4mm Torx #4 screw that's securing the battery connector.
      Ask FixBot
    5. Nokia Lumia 930 Camera Replacement: step 5, image 1 of 1
      • Use tweezers to remove the battery connector strap.
      Ask FixBot
    6. Nokia Lumia 930 Camera Replacement: step 6, image 1 of 2 Nokia Lumia 930 Camera Replacement: step 6, image 2 of 2
      • Remove all ten 4mm Torx #4 screws that secure the battery cover to the frame of the phone.
      Ask FixBot
    7. Nokia Lumia 930 Camera Replacement: step 7, image 1 of 3 Nokia Lumia 930 Camera Replacement: step 7, image 2 of 3 Nokia Lumia 930 Camera Replacement: step 7, image 3 of 3
      • Use the flat end of a spudger to pry the battery cover from the phone's frame.
      Ask FixBot
    8. Nokia Lumia 930 Camera Replacement: step 8, image 1 of 1
      • Pull up on the heat spreader.
      • Be careful not to tear it!
      Ask FixBot
    9. Nokia Lumia 930 Camera Replacement: step 9, image 1 of 1
      • Use the flat end of the spudger to lift up the battery.
      • The battery is glued in place. Pry up carefully, not to damage it.
      • Two flex cables are directly underneath the battery.
      Ask FixBot
    10. Nokia Lumia 930 Camera Replacement: step 10, image 1 of 1
      • Remove the battery from the phone.
      Ask FixBot
    1. Nokia Lumia 930 Camera Replacement, Motherboard: step 11, image 1 of 2 Nokia Lumia 930 Camera Replacement, Motherboard: step 11, image 2 of 2
      • Use the flat end of a spudger to disconnect the camera connectors.
      • Pull the camera up and out to remove it from the phone.
      Ask FixBot
    2. Nokia Lumia 930 Camera Replacement: step 12, image 1 of 1
      • Use the flat end of a spudger to disconnect the six ribbon cables from the motherboard.
      Ask FixBot
    3. Nokia Lumia 930 Camera Replacement: step 13, image 1 of 3 Nokia Lumia 930 Camera Replacement: step 13, image 2 of 3 Nokia Lumia 930 Camera Replacement: step 13, image 3 of 3
      • Use the flat end of a spudger to pry up the orange flex cable underneath the battery.
      • Remove the orange flex cable from the phone.
      Ask FixBot
    4. Nokia Lumia 930 Camera Replacement: step 14, image 1 of 1
      • Repeat the previous step for the black jumper flex cable under the battery.
      Ask FixBot
    5. Nokia Lumia 930 Camera Replacement: step 15, image 1 of 2 Nokia Lumia 930 Camera Replacement: step 15, image 2 of 2
      • Use the flat end of a spudger to disconnect both ends of the antenna cable from the motherboard.
      • Remove the antenna.
      Ask FixBot
    6. Nokia Lumia 930 Camera Replacement: step 16, image 1 of 1
      Buy
      • Use tweezers to grab the adhesive that is under the LTE flex cable and pull it outwards and towards the bottom end of the phone.
      • Apply new adhesive when reassembling the phone.
      Ask FixBot
    7. Nokia Lumia 930 Camera Replacement: step 17, image 1 of 3 Nokia Lumia 930 Camera Replacement: step 17, image 2 of 3 Nokia Lumia 930 Camera Replacement: step 17, image 3 of 3
      • Use a spudger to pry up the bottom end of the motherboard, then pull it out.
      Ask FixBot
    1. Nokia Lumia 930 Camera Replacement, Camera: step 18, image 1 of 1
      • Use the flat edge of a spudger to disconnect the camera.
      • Remove the camera.
      Ask FixBot
calvin
73 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 36
All Time: 740
