Nokia Lumia 720 Loudspeaker & Antenna module Replacement
Video Overview
  1. Nokia Lumia 720 Loudspeaker & Antenna module Replacement, BATTERY COVER - PART 1: step 1, image 1 of 3 Nokia Lumia 720 Loudspeaker & Antenna module Replacement, BATTERY COVER - PART 1: step 1, image 2 of 3 Nokia Lumia 720 Loudspeaker & Antenna module Replacement, BATTERY COVER - PART 1: step 1, image 3 of 3
    • Remove the SIM card tray and the memory card try.
    • Use a screwdriver Torx T2 and remove the screw under the SIM card tray.
    • Use plastic tools and start the separating the back cover from the top side.
  2. Nokia Lumia 720 Loudspeaker & Antenna module Replacement, BATTERY COVER - PART 2: step 2, image 1 of 3 Nokia Lumia 720 Loudspeaker & Antenna module Replacement, BATTERY COVER - PART 2: step 2, image 2 of 3 Nokia Lumia 720 Loudspeaker & Antenna module Replacement, BATTERY COVER - PART 2: step 2, image 3 of 3
    • Be careful with the volume buttons.
  3. Nokia Lumia 720 Loudspeaker & Antenna module Replacement, Loudspeaker & Antenna module: step 3, image 1 of 3 Nokia Lumia 720 Loudspeaker & Antenna module Replacement, Loudspeaker & Antenna module: step 3, image 2 of 3 Nokia Lumia 720 Loudspeaker & Antenna module Replacement, Loudspeaker & Antenna module: step 3, image 3 of 3
    • Remove the 3x Torx T4 screws.
    • Buzzer / Loudspeacker
ZFix
191,308 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,532 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 459
