Nokia Lumia 620 Volume and Power Button Replacement
  1. Nokia Lumia 620 Volume and Power Button Replacement, Volume and Power Button: step 1, image 1 of 1
    • Check condition of switches on logicboard
    • Rule out failure of cover
  2. Nokia Lumia 620 Volume and Power Button Replacement: step 2, image 1 of 1
    • Torx 6 screwdriver
    • Soldering iron (thin tip)
    • Decent quality solder (thin wire)
  3. Nokia Lumia 620 Volume and Power Button Replacement: step 3, image 1 of 1
    • Remove cover, battery and SIM
    • Remove 6 torx screws
    • Note: Green is fine thread
    • Note: Red is coarse thread
  4. Nokia Lumia 620 Volume and Power Button Replacement: step 4, image 1 of 2 Nokia Lumia 620 Volume and Power Button Replacement: step 4, image 2 of 2
    • Remove plastic clover near battery
    • Keep track of all parts
  5. Nokia Lumia 620 Volume and Power Button Replacement: step 5, image 1 of 1
    • Gently release logicboard connectors
  6. Nokia Lumia 620 Volume and Power Button Replacement, Remove logic board: step 6, image 1 of 2 Nokia Lumia 620 Volume and Power Button Replacement, Remove logic board: step 6, image 2 of 2
    • There is a clip that needs to be moved out of the way before the board will move.
    • Start by lifting long side of logicboard
    • Gently wiggle and lift
    • Undo plastic clips near battery with force
  7. Nokia Lumia 620 Volume and Power Button Replacement: step 7, image 1 of 1
    • Check connections of failed buttons
  8. Nokia Lumia 620 Volume and Power Button Replacement: step 8, image 1 of 1
    • Resolder broken connections
    • Make sure the pads do not short
  9. Nokia Lumia 620 Volume and Power Button Replacement: step 9, image 1 of 1
    • Put back logicboard
    • Make sure pins near camera line-up
    • Note: Plastic clips need quite some force
  10. Nokia Lumia 620 Volume and Power Button Replacement: step 10, image 1 of 1
    • Reconnect logicboard connectors
  11. Nokia Lumia 620 Volume and Power Button Replacement: step 11, image 1 of 1
    • Put back plastic cover
  12. Nokia Lumia 620 Volume and Power Button Replacement: step 12, image 1 of 1
    • Gently tighten screws
    • Put back SIM card and battery
    • Close cover
    • Enjoy the result ;)
Finish Line
11 other people completed this guide.
Anne
456 Reputation
1 Guide authored
4 Comments
Realmente funcionó el tutorial, sirven de nuevo los dos botones que fallaban.
Gaia501 - Reply
Only the 2 middle screws are fine threaded. And you can see in the pictures here, that there are 4 coarse threaded ones and 2 fine threaded ones. The green one in the corner should be red
shadow118 - Reply
hafıza kart okuyucu çalışmıyor ne yapmam lazım
davutcigir - Reply
Omg it looks complicated
Maz Hanvey - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 16
All Time: 10,178
