Removing or Installing Nokia E90 Inside Screen
  1. Removing or Installing Nokia E90 Inside Screen, Front Cover: step 1, image 1 of 1
    • Start with the phone in the flipped open position.
    • You must remove the sticker in the center, below the screen to reveal the center screw.
    • Use a T5 screwdriver to remove all three screws, loosening the front screen.
  2. Removing or Installing Nokia E90 Inside Screen: step 2, image 1 of 2 Removing or Installing Nokia E90 Inside Screen: step 2, image 2 of 2
    • Flip the phone to the closed position and turn to the front screen.
    • The front cover will now be loose enough for you to remove by grabbing the edges and lightly pulling the cover off.
  3. Removing or Installing Nokia E90 Inside Screen, Front Screen and Front Keypad: step 3, image 1 of 1
    • With the front cover off, the screen and keypad should be loose.
  4. Removing or Installing Nokia E90 Inside Screen: step 4, image 1 of 2 Removing or Installing Nokia E90 Inside Screen: step 4, image 2 of 2
    • Using a plastic opening tool pry up the cable connecting the LCD screen to the rest of the phone.
    • With the cable disconnected, the screen should be free for removal or replacement.
  5. Removing or Installing Nokia E90 Inside Screen, Inside Screen: step 5, image 1 of 1
    • After removing the front screen and front keypad, your device should look like this.
  6. Removing or Installing Nokia E90 Inside Screen: step 6, image 1 of 3 Removing or Installing Nokia E90 Inside Screen: step 6, image 2 of 3 Removing or Installing Nokia E90 Inside Screen: step 6, image 3 of 3
    • Using the T5 Screwdriver, remove the two screws shown.
  7. Removing or Installing Nokia E90 Inside Screen: step 7, image 1 of 1
    • Make sure to remove the connection shown by gently easing the plastic opening tool underneath the connection and lightly prying the connection apart.
  8. Removing or Installing Nokia E90 Inside Screen: step 8, image 1 of 2 Removing or Installing Nokia E90 Inside Screen: step 8, image 2 of 2
    • Gently, lift the board up to reveal the front screen.
  9. Removing or Installing Nokia E90 Inside Screen: step 9, image 1 of 3 Removing or Installing Nokia E90 Inside Screen: step 9, image 2 of 3 Removing or Installing Nokia E90 Inside Screen: step 9, image 3 of 3
    • Using the plastic opening tool, lift and remove the inside screen.
Cameron Weinberg
540 Reputation
6 Guides authored
Cal Poly, Team 18-21, Garner Spring 2011 Member of Cal Poly, Team 18-21, Garner Spring 2011
CPSU-GARNER-S11S18G21
3 Members
8 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 5,326
