This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Nokia 6630 Battery Replacement
    1. Nokia 6630 Battery Replacement, Power off the phone: step 1, image 1 of 1
      • Completely power off the Nokia 6630 before you begin the replacement. If the phone is connected to a charger, disconnect the cable.
      Ask FixBot
    2. Nokia 6630 Battery Replacement, Remove the rear cover: step 2, image 1 of 1
      • Turn the phone over with the display facing down. Locate the rear cover latch, then press or slide the release mechanism and gently remove the cover.
      Ask FixBot
    3. Nokia 6630 Battery Replacement, Remove the old battery: step 3, image 1 of 1
      • Lift the battery using the pull tab or the recess on the edge.
      • Do not use metal objects and do not force the battery, especially if it appears swollen or damaged.
      Ask FixBot
    4. Nokia 6630 Battery Replacement, Insert the new battery: step 4, image 1 of 1
      • Place the new battery into the recess, making sure it is oriented correctly. The metal contacts on the battery must align with the corresponding contacts in the phone.
      Ask FixBot
Attached Documents
Piero Sabino
1,216 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 64
All Time: 78
