Repairing Nokia 6560 Display
  1. Repairing Nokia 6560 Display, Battery: step 1, image 1 of 2 Repairing Nokia 6560 Display, Battery: step 1, image 2 of 2
    • Remove the back cover of your cell phone by pushing the small slider with your fingernail towards the top of the phone.
    • Lift off your cell phone's back cover.
  2. Repairing Nokia 6560 Display: step 2, image 1 of 2 Repairing Nokia 6560 Display: step 2, image 2 of 2
    • Use your index finger to first push down and then lift up the battery as shown.
    • Remove the battery from your cell phone.
  3. Repairing Nokia 6560 Display, Keypad: step 3, image 1 of 2 Repairing Nokia 6560 Display, Keypad: step 3, image 2 of 2
    • Open the front cover of your cell phone with the plastic opening tool or finger nail.
    • Lift the cover upwards, starting from the bottom below the keypad.
  4. Repairing Nokia 6560 Display: step 4, image 1 of 2 Repairing Nokia 6560 Display: step 4, image 2 of 2
    • Lift the keypad off of the keyboard as it is not attached to the phone anymore.
    • If you want to clean your keyboard do not use chemical cleaners or too much water, instead, use a damp cloth.
    • It may be tricky to get the keypad in the right position while closing the front cover for the reassembly. Ensure they are aligned properly before closing the front cover!
  5. Repairing Nokia 6560 Display, Keyboard: step 5, image 1 of 1
    • Unscrew the six T6 torx screws which attach the frame to the cell phone case.
    • Be careful not to scratch your display with the screw driver.
  6. Repairing Nokia 6560 Display: step 6, image 1 of 1
    • Lift the frame off of your cell phone.
  7. Repairing Nokia 6560 Display: step 7, image 1 of 1
    • Lift the keyboard out of the plastic frame.
  8. Repairing Nokia 6560 Display, Display: step 8, image 1 of 2 Repairing Nokia 6560 Display, Display: step 8, image 2 of 2
    • Use the plastic opening tool to unmount the thin metal frame at the tab connections. You must do this on both sides.
    • Lift the thin metal frame off of the plastic frame.
    • Pay attention while lifting the frame off because it can easily be bent.
  9. Repairing Nokia 6560 Display: step 9, image 1 of 3 Repairing Nokia 6560 Display: step 9, image 2 of 3 Repairing Nokia 6560 Display: step 9, image 3 of 3
    • Pull the sides of the plastic frame apart in order to loosen the display.
    • Take the display out of the plastic frame.
Nathan Whitacre
21 Reputation
2 Guides authored
Cal Poly, Team 3-17, Maness Winter 2010 Member of Cal Poly, Team 3-17, Maness Winter 2010
CPSU-MANESS-W10S3G17
4 Members
12 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 1,707
