Installing Nokia 6310i Motherboard
  1. Installing Nokia 6310i Motherboard, Battery: step 1, image 1 of 2 Installing Nokia 6310i Motherboard, Battery: step 1, image 2 of 2
    • Press and hold the battery release button and slide the battery away from the Nokia logo
  2. Installing Nokia 6310i Motherboard, SIM card: step 2, image 1 of 3 Installing Nokia 6310i Motherboard, SIM card: step 2, image 2 of 3 Installing Nokia 6310i Motherboard, SIM card: step 2, image 3 of 3
    • Slide the SIM card lock away from the SIM card.
    • The SIM card pops out. Remove the SIM card.
  3. Installing Nokia 6310i Motherboard, Back Cover: step 3, image 1 of 1
    • Unscrew and remove the four T6 Torx screws.
  4. Installing Nokia 6310i Motherboard: step 4, image 1 of 3 Installing Nokia 6310i Motherboard: step 4, image 2 of 3 Installing Nokia 6310i Motherboard: step 4, image 3 of 3
    • Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone.
  5. Installing Nokia 6310i Motherboard: step 5, image 1 of 3 Installing Nokia 6310i Motherboard: step 5, image 2 of 3 Installing Nokia 6310i Motherboard: step 5, image 3 of 3
    • Use the plastic opening tool to separate the top part of the backplate.
    • The plastic clips at the top require slightly more force to separate.
  6. Installing Nokia 6310i Motherboard, Antenna: step 6, image 1 of 2 Installing Nokia 6310i Motherboard, Antenna: step 6, image 2 of 2
    • Remove the screw holding the antenna to the circuit board.
    • Carefully lift off the antenna from the circuit board.
  7. Installing Nokia 6310i Motherboard, Motherboard: step 7, image 1 of 3 Installing Nokia 6310i Motherboard, Motherboard: step 7, image 2 of 3 Installing Nokia 6310i Motherboard, Motherboard: step 7, image 3 of 3
    • Lift off the logic board from the faceplate.
Mustafa
156 Reputation
4 Guides authored
Cal Poly, Team 14-41, Forte Fall 2010 Member of Cal Poly, Team 14-41, Forte Fall 2010
CPSU-FORTE-F10S14G41
5 Members
16 Guides authored
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 15
All Time: 7,126
