Disassembling Nokia 6236i Front Casing
  1. Disassembling Nokia 6236i Front Casing, Battery: step 1, image 1 of 2 Disassembling Nokia 6236i Front Casing, Battery: step 1, image 2 of 2
    • Using your thumb, apply pressure to the battery casing (below the camera). Firmly pull towards the bottom of the phone.
    • Lift the battery case off of the phone.
  2. Disassembling Nokia 6236i Front Casing: step 2, image 1 of 3 Disassembling Nokia 6236i Front Casing: step 2, image 2 of 3 Disassembling Nokia 6236i Front Casing: step 2, image 3 of 3
    • Use your thumb to get underneath the battery and pull up and out from the bottom of the battery tray.
    • The battery should lift out with minimal resistance.
  3. Disassembling Nokia 6236i Front Casing, SIM Card: step 3, image 1 of 3 Disassembling Nokia 6236i Front Casing, SIM Card: step 3, image 2 of 3 Disassembling Nokia 6236i Front Casing, SIM Card: step 3, image 3 of 3
    • Once the battery is removed, pull the tab of the metal sim card cover, and lift it up.
    • The sim card is underneath and can now be removed.
  4. Disassembling Nokia 6236i Front Casing, Disassembling Nokia 6236i Front Casing: step 4, image 1 of 3 Disassembling Nokia 6236i Front Casing, Disassembling Nokia 6236i Front Casing: step 4, image 2 of 3 Disassembling Nokia 6236i Front Casing, Disassembling Nokia 6236i Front Casing: step 4, image 3 of 3
    • Locate the notch on the bottom right corner of the phone.
    • Slide the head of the screwdriver between the front silver casing and the black back side of the phone.
    • While inserted, slide the screwdriver towards the top edge of the phone.
    • The front casing should eventually pop off.
Erik Lindahl
63 Reputation
4 Guides authored
Cal Poly, Team 10-46, Garner Spring 2010 Member of Cal Poly, Team 10-46, Garner Spring 2010
CPSU-GARNER-S10S10G46
4 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 1,869
