Nokia 6085h Front LCD Display
  1. Nokia 6085h Front LCD Display, Battery: step 1, image 1 of 1
    • Flip over the phone so that the back is facing up.
    • Pressing your thumb against the back cover, slide the cover off of the phone.
  2. Nokia 6085h Front LCD Display: step 2, image 1 of 1
    • Remove the phone's battery.
  3. Nokia 6085h Front LCD Display, Front LCD Display: step 3, image 1 of 3 Nokia 6085h Front LCD Display, Front LCD Display: step 3, image 2 of 3 Nokia 6085h Front LCD Display, Front LCD Display: step 3, image 3 of 3
    • With the phone closed, run a plastic opening tool along the seam of the top half of the phone
    • Make sure to disconnect each of the five clips before proceeding (2 on each side, 1 on top)
  4. Nokia 6085h Front LCD Display: step 4, image 1 of 2 Nokia 6085h Front LCD Display: step 4, image 2 of 2
    • Using T6 Torx Screwdriver, remove the four 3.16mm screws from the front panel
    • Note that the fourth screw is under a fold in the ribbon cable
  5. Nokia 6085h Front LCD Display: step 5, image 1 of 3 Nokia 6085h Front LCD Display: step 5, image 2 of 3 Nokia 6085h Front LCD Display: step 5, image 3 of 3
    • Starting in the lower right corner, slowly start to lift the tape that is holding the front LCD and cables down
    • Be careful around the two ribbon cables that are attached to the tape, they are fragile
    • Lift the tape from the board
  6. Nokia 6085h Front LCD Display: step 6, image 1 of 1
    • Using a plastic opening tool, lift the ribbon cable connection below the front LCD
  7. Nokia 6085h Front LCD Display: step 7, image 1 of 3 Nokia 6085h Front LCD Display: step 7, image 2 of 3 Nokia 6085h Front LCD Display: step 7, image 3 of 3
    • Using a plastic opening tool, slowly pry up the LCD display from the bottom, releasing it from the glue holding it to the board
Brett Balcer
240 Reputation
2 Guides authored
Cal Poly, Team 4-46, Amido Fall 2010 Member of Cal Poly, Team 4-46, Amido Fall 2010
CPSU-AMIDO-F10S4G46
4 Members
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 15
All Time: 1,113
