Introduction
This guide give instructions on how to locate the front LCD display for removal and/or repair.
Flip over the phone so that the back is facing up.
Pressing your thumb against the back cover, slide the cover off of the phone.
With the phone closed, run a plastic opening tool along the seam of the top half of the phone.
Make sure to disconnect each of the five clips before proceeding (2 on each side, 1 on top).
Using T6 Torx Screwdriver, remove the four 3.16mm screws from the front panel
Note that the fourth screw is under a fold in the ribbon cable
Starting in the lower right corner, slowly start to lift the tape that is holding the front LCD and cables down
Be careful around the two ribbon cables that are attached to the tape, they are fragile
Lift the tape from the board
Using a plastic opening tool, slowly pry up the LCD display from the bottom, releasing it from the glue holding it to the board
