Installing Nokia 6030 Speaker/Antenna
  1. Installing Nokia 6030 Speaker/Antenna, Battery: step 1, image 1 of 3 Installing Nokia 6030 Speaker/Antenna, Battery: step 1, image 2 of 3 Installing Nokia 6030 Speaker/Antenna, Battery: step 1, image 3 of 3
    • Press down on the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
  2. Installing Nokia 6030 Speaker/Antenna: step 2, image 1 of 3 Installing Nokia 6030 Speaker/Antenna: step 2, image 2 of 3 Installing Nokia 6030 Speaker/Antenna: step 2, image 3 of 3
    • Use your finger to gently pull the bottom of the battery up by using the slip found at the bottom of the phone.
    • Lift out battery and remove.
  3. Installing Nokia 6030 Speaker/Antenna, SIM Card: step 3, image 1 of 3 Installing Nokia 6030 Speaker/Antenna, SIM Card: step 3, image 2 of 3 Installing Nokia 6030 Speaker/Antenna, SIM Card: step 3, image 3 of 3
    • Use your finger to lift the metal cage up.
    • Remove SIM card.
  4. Installing Nokia 6030 Speaker/Antenna: step 4, image 1 of 1
    • Use your finger to close the metal cage.
  5. Installing Nokia 6030 Speaker/Antenna, Front Cover: step 5, image 1 of 3 Installing Nokia 6030 Speaker/Antenna, Front Cover: step 5, image 2 of 3 Installing Nokia 6030 Speaker/Antenna, Front Cover: step 5, image 3 of 3
    • Insert your two fingers under the two tabs found at the top of the phone underneath the black casing, then pull the casing up and slide it out slowly.
  6. Installing Nokia 6030 Speaker/Antenna: step 6, image 1 of 2 Installing Nokia 6030 Speaker/Antenna: step 6, image 2 of 2
    • After removing the top cover, turn the phone over so the screen is facing upwards.
  7. Installing Nokia 6030 Speaker/Antenna: step 7, image 1 of 3 Installing Nokia 6030 Speaker/Antenna: step 7, image 2 of 3 Installing Nokia 6030 Speaker/Antenna: step 7, image 3 of 3
    • Use your fingers to slowly lift the screen back towards the bottom of the phone using the arrows found at the top of the phone.
  8. Installing Nokia 6030 Speaker/Antenna, Speaker/Antenna: step 8, image 1 of 3 Installing Nokia 6030 Speaker/Antenna, Speaker/Antenna: step 8, image 2 of 3 Installing Nokia 6030 Speaker/Antenna, Speaker/Antenna: step 8, image 3 of 3
    • Remove the six screws with a T-6 star screwdriver.
  9. Installing Nokia 6030 Speaker/Antenna: step 9, image 1 of 3 Installing Nokia 6030 Speaker/Antenna: step 9, image 2 of 3 Installing Nokia 6030 Speaker/Antenna: step 9, image 3 of 3
    • Lift the logic board and screen from the top.
    • Be careful of loose parts.
  10. Installing Nokia 6030 Speaker/Antenna: step 10, image 1 of 3 Installing Nokia 6030 Speaker/Antenna: step 10, image 2 of 3 Installing Nokia 6030 Speaker/Antenna: step 10, image 3 of 3
    • Lift the speaker out of the back housing of the phone.
    • The speaker should come out with little effort.
Spencer Woodworth
316 Reputation
9 Guides authored
Cal Poly, Team 23-63, Johann Spring 2010 Member of Cal Poly, Team 23-63, Johann Spring 2010
CPSU-JOHANN-S10S23G63
3 Members
17 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 3,962
