Introduction
Guide to replace the phones speaker.
Press down on the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
Use your finger to gently pull the bottom of the battery up by using the slip found at the bottom of the phone.
Lift out battery and remove.
Insert your two fingers under the two tabs found at the top of the phone underneath the black casing, then pull the casing up and slide it out slowly.
Use your fingers to slowly lift the screen back towards the bottom of the phone using the arrows found at the top of the phone.
Lift the speaker out of the back housing of the phone.
The speaker should come out with little effort.
