Introduction
Replacing the glass/front cover of the phone.
Press down on the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
Use your finger to gently pull the bottom of the battery up by using the slip found at the bottom of the phone.
Lift out battery and remove.
Insert both of your thumbs under the two tabs labeled with the arrows and pull the top casing up. then slowly rotate up and over the screen.
