Nokia 3300B Keyboard Replacement.
  1. Nokia 3300B Keyboard Replacement., Battery: step 1, image 1 of 2 Nokia 3300B Keyboard Replacement., Battery: step 1, image 2 of 2
    • Flip the Nokia 3300B over with the back-side facing towards you.
    • Gently press the button on the back of the battery cover to release the cover and slide up.
  2. Nokia 3300B Keyboard Replacement.: step 2, image 1 of 2 Nokia 3300B Keyboard Replacement.: step 2, image 2 of 2
    • Lift the battery out of the back of the phone.
    • It is easiest to lift the battery out of the phone from the right-hand side, as seen in the picture.
  3. Nokia 3300B Keyboard Replacement., Keyboard: step 3, image 1 of 2 Nokia 3300B Keyboard Replacement., Keyboard: step 3, image 2 of 2
    • Gently push the blue tabs on the top of the phone out of their slots.
    • With the phone facing up, pop the blue faceplate off by using your fingernail (or some tweezers) and working your way around the phone.
    • Note: If the blue cover does not detach easily use your finger nails to try and split it open, as seen in the picture.
  4. Nokia 3300B Keyboard Replacement.: step 4, image 1 of 1
    • With the screen still facing you, lift and remove the blue faceplate.
  5. Nokia 3300B Keyboard Replacement.: step 5, image 1 of 1
    • Grab the sides of the keypad and lift each side up vertically, until the keypad is completely removed.
    • If you encounter resistance while removing the keypad, be sure to lift up evenly on both sides to ensure that the pins do not snap.
    • When replacing the keypad, make sure that the plastic pegs all enter their proper holes.
3 other people completed this guide.
Chris Colwell
107 Reputation
2 Guides authored
Cal Poly, Team 18-65, Johann Spring 2010 Member of Cal Poly, Team 18-65, Johann Spring 2010
CPSU-JOHANN-S10S18G65
4 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 17
All Time: 2,798
