Nokia 2660 Flip Keypad Replacement
    1. Nokia 2660 Flip Keypad Replacement, Battery: step 1, image 1 of 3 Nokia 2660 Flip Keypad Replacement, Battery: step 1, image 2 of 3 Nokia 2660 Flip Keypad Replacement, Battery: step 1, image 3 of 3
      • Turn your Nokia around to the rear side.
      • Insert a spudger or your fingernail into the notch on the bottom of the device.
      Ask FixBot
    2. Nokia 2660 Flip Keypad Replacement: step 2, image 1 of 3 Nokia 2660 Flip Keypad Replacement: step 2, image 2 of 3 Nokia 2660 Flip Keypad Replacement: step 2, image 3 of 3
      • Pry the rear casing out towards you.
      Ask FixBot
    3. Nokia 2660 Flip Keypad Replacement: step 3, image 1 of 3 Nokia 2660 Flip Keypad Replacement: step 3, image 2 of 3 Nokia 2660 Flip Keypad Replacement: step 3, image 3 of 3
      • Insert a spudger or fingernail into the slot.
      • Gently remove the battery out of the slot.
      • Keep in mind inserting the new battery into the prongs.
      Ask FixBot
    1. Nokia 2660 Flip Keypad Replacement, Motherboard: step 4, image 1 of 3 Nokia 2660 Flip Keypad Replacement, Motherboard: step 4, image 2 of 3 Nokia 2660 Flip Keypad Replacement, Motherboard: step 4, image 3 of 3
      • Remove the screws using the TR6 Torx screwdriver.
      • Lift up the red casing with a spudger to reveal the motherboard.
      Ask FixBot
    2. Nokia 2660 Flip Keypad Replacement: step 5, image 1 of 3 Nokia 2660 Flip Keypad Replacement: step 5, image 2 of 3 Nokia 2660 Flip Keypad Replacement: step 5, image 3 of 3
      • Be very gentle with the motherboard as pulling too harshly can damage the ribbon cable.
      • With a clean fingernail or spudger, detach the ribbon cable.
      • Use a Jimmy to lift the motherboard up and place it to the side.
      • Once the motherboard has been removed check for any damages, if there are any you must safely dispose of the motherboard itself.
      Ask FixBot
    1. Nokia 2660 Flip Keypad Replacement, Keypad: step 6, image 1 of 3 Nokia 2660 Flip Keypad Replacement, Keypad: step 6, image 2 of 3 Nokia 2660 Flip Keypad Replacement, Keypad: step 6, image 3 of 3
      • Remove the plastic holders from the slots with a spudger.
      • Lift up the keypad out of the slot.
      • When putting the new keypad in remember to put the plastic holders back in.
      Ask FixBot
Kobe Rouke
521 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 62
All Time: 180
