Nokia 2630b Screen / Front Case Replacement
  1. Nokia 2630b Screen / Front Case Replacement, Battery Case: step 1, image 1 of 2 Nokia 2630b Screen / Front Case Replacement, Battery Case: step 1, image 2 of 2
    • Press each release button on either side of the battery cover and simultaneously remove the battery cover from the phone.
  2. Nokia 2630b Screen / Front Case Replacement: step 2, image 1 of 1
    • Pull the battery out of the phone with your fingers.
  3. Nokia 2630b Screen / Front Case Replacement, Screen / Front Case: step 3, image 1 of 1
    • Remove the two screws on either side of the battery case using the microscrewdriver using the T5 bit
    • The T5 bit has a star shaped end and has "T5" engraved on the side of the bit for easy identification
    • NOTE: Keep the screws in a safe place while you continue working.
  4. Nokia 2630b Screen / Front Case Replacement: step 4, image 1 of 3 Nokia 2630b Screen / Front Case Replacement: step 4, image 2 of 3 Nokia 2630b Screen / Front Case Replacement: step 4, image 3 of 3
    • Separate the front case from the back case using the iPod opener
    • NOTE: The keypad is a loose piece and may fall out
  5. Nokia 2630b Screen / Front Case Replacement: step 5, image 1 of 1
    • Remove screws using the same T5 screw bit to release the computer chip from the case
  6. Nokia 2630b Screen / Front Case Replacement: step 6, image 1 of 1
    • Carefully lift the black frame off the screen with your fingers
  7. Nokia 2630b Screen / Front Case Replacement: step 7, image 1 of 1
    • Carefully remove the computer chip and screen out of the black case with your fingers
  8. Nokia 2630b Screen / Front Case Replacement: step 8, image 1 of 2 Nokia 2630b Screen / Front Case Replacement: step 8, image 2 of 2
    • The screen is attached to the motherboard by an orange ribbon
    • Carefully detach the ribbon from the motherboard using your fingers
  9. Nokia 2630b Screen / Front Case Replacement: step 9, image 1 of 1
    • Reattach new screen by connecting the orange ribbon to the computer chip
  10. Nokia 2630b Screen / Front Case Replacement: step 10, image 1 of 2 Nokia 2630b Screen / Front Case Replacement: step 10, image 2 of 2
    • Place computer chip and screen back into black case
  11. Nokia 2630b Screen / Front Case Replacement: step 11, image 1 of 1
    • Place black frame back over screen
  12. Nokia 2630b Screen / Front Case Replacement: step 12, image 1 of 2 Nokia 2630b Screen / Front Case Replacement: step 12, image 2 of 2
    • Carefully place keypad back in place
  13. Nokia 2630b Screen / Front Case Replacement: step 13, image 1 of 2 Nokia 2630b Screen / Front Case Replacement: step 13, image 2 of 2
    • Snap the front case back in place with the bottom case with your fingers
  14. Nokia 2630b Screen / Front Case Replacement: step 14, image 1 of 1
    • Reassemble screws with microscrewdriver
  15. Nokia 2630b Screen / Front Case Replacement: step 15, image 1 of 1
    • Slide battery back into place
  16. Nokia 2630b Screen / Front Case Replacement: step 16, image 1 of 1
    • Snap battery cover back into place
To reassemble your device, follow these instructions in reverse order. Make sure to snap the new screen / front case securely into place.
Eric
51 Reputation
4 Guides authored
Cal Poly, Team 9-61, Walters Spring 2011 Member of Cal Poly, Team 9-61, Walters Spring 2011
CPSU-WALTERS-S11S9G61
5 Members
5 Guides authored
2 Comments
Great guide :-) I have a Nokia 2630 too and people can no longer hear me on calls, even though I can hear them. Do you know what could be wrong? Do you think this is something I could fix myself? Thanks!
jfg - Reply
You could try getting a neodymium magnet and run it across the earpiece grill. In my father's case, a lot of metal powder was in there, pressing in the speaker membrane; the alternative is cleaning it (which does require opening the phone using Eric's very nice guide). The alternative to those is ordering an earpiece online - but usually those are really bad quality, so trying to fix the original one would be advisable
Darie H -
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 14
All Time: 3,809
