Nokia 1100b RH-36 Screen Replacement
  1. Nokia 1100b RH-36 Screen Replacement, Battery Cover: step 1, image 1 of 2 Nokia 1100b RH-36 Screen Replacement, Battery Cover: step 1, image 2 of 2
    • Flip the phone over so that the screen faces down.
    • Press the gray button on the battery cover and slide it down off the back of the phone.
  2. Nokia 1100b RH-36 Screen Replacement, Battery: step 2, image 1 of 1
    • Wedge the flat end of the spudger into the small indent next to the Nokia logo on the battery.
    • Gently pry the battery out of the phone.
  3. Nokia 1100b RH-36 Screen Replacement, Removing Nokia 1100b RH-36 Front Cover: step 3, image 1 of 2 Nokia 1100b RH-36 Screen Replacement, Removing Nokia 1100b RH-36 Front Cover: step 3, image 2 of 2
    • Firmly grip the back of the casing.
    • Separate the front and back casings either by pulling them apart from the middle or gently prying the front off with your fingers from the bottom.
    • Be sure not to bend the casing too much when prying from the bottom. Failure to do so may cause it to crack.
  4. Nokia 1100b RH-36 Screen Replacement, Inner Casing: step 4, image 1 of 2 Nokia 1100b RH-36 Screen Replacement, Inner Casing: step 4, image 2 of 2
    • Remove the six 6mm T6 Torx screws around the edge of the front of the phone.
    • Remove the metal frame holding the screen and speaker.
  5. Nokia 1100b RH-36 Screen Replacement, Screen: step 5, image 1 of 2 Nokia 1100b RH-36 Screen Replacement, Screen: step 5, image 2 of 2
    • Flip over the metal frame you just removed.
    • Using the flat end of the spudger, pry apart the inner clear plastic frame with screen attached from the metal frame.
    • Remove the screen bearing plastic frame.
JSwan
751 Reputation
6 Guides authored
Cal Poly, Team 10-43, Amido Spring 2013 Member of Cal Poly, Team 10-43, Amido Spring 2013
CPSU-AMIDO-S13S10G43
4 Members
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 29
All Time: 1,827
