Nokia 1100b RH-36 Motherboard and Keyboard Replacement
  1. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Battery Cover: step 1, image 1 of 2 Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Battery Cover: step 1, image 2 of 2
    • Flip the phone over so that the screen faces down.
    • Press the gray button on the battery cover and slide it down off the back of the phone.
  2. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Battery: step 2, image 1 of 1
    • Wedge the flat end of the spudger into the small indent next to the Nokia logo on the battery.
    • Gently pry the battery out of the phone.
  3. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Inner Casing: step 3, image 1 of 2 Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Inner Casing: step 3, image 2 of 2
    • Remove the six 6mm T6 Torx screws around the edge of the front of the phone.
    • Remove the metal frame holding the screen and speaker.
  4. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Motherboard and Keyboard: step 4, image 1 of 2 Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Motherboard and Keyboard: step 4, image 2 of 2
    • Gently lift motherboard unit out of the case.
    • The motherboard and keyboard are one unit and are replaced together.
James Szelenyi
262 Reputation
1 Guide authored
Cal Poly, Team 10-43, Amido Spring 2013 Member of Cal Poly, Team 10-43, Amido Spring 2013
CPSU-AMIDO-S13S10G43
4 Members
14 Guides authored
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 35
All Time: 4,258
