Nintendo Wii Outer Case Replacement
  1. Nintendo Wii Outer Case Replacement, Faceplate: step 1, image 1 of 2 Nintendo Wii Outer Case Replacement, Faceplate: step 1, image 2 of 2
    • Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
  2. Nintendo Wii Outer Case Replacement: step 2, image 1 of 1
    • Remove the two 8.3 mm Tri-Point screws hidden under the covers you just removed.
  3. Nintendo Wii Outer Case Replacement: step 3, image 1 of 1
    • Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
  4. Nintendo Wii Outer Case Replacement: step 4, image 1 of 1
    • Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
  5. Nintendo Wii Outer Case Replacement: step 5, image 1 of 1
    • Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
  6. Nintendo Wii Outer Case Replacement: step 6, image 1 of 2 Nintendo Wii Outer Case Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Carefully pull the faceplate away from the front of the Wii.
    • Use a pair of tweezers to disconnect the LED cable's plastic connector from the motherboard.
    • Remove the faceplate.
  7. Nintendo Wii Outer Case Replacement, Outer Case: step 7, image 1 of 3 Nintendo Wii Outer Case Replacement, Outer Case: step 7, image 2 of 3 Nintendo Wii Outer Case Replacement, Outer Case: step 7, image 3 of 3
    • Open the controller port cover until it is perpendicular to the black controller port bezel.
    • Pull the controller port cover straight up to release it from the outer case.
    • Repeat this procedure for the memory card port cover.
  8. Nintendo Wii Outer Case Replacement: step 8, image 1 of 2 Nintendo Wii Outer Case Replacement: step 8, image 2 of 2
    • Remove the two remaining 4.1 mm Phillips screws along the top edge of the black plastic controller port bezel.
    • Lift the bezel from the long edge furthest away from the controller ports and remove it from the Wii.
  9. Nintendo Wii Outer Case Replacement: step 9, image 1 of 1
    • Remove the two 5 mm Phillips screws above the controller ports.
  10. Nintendo Wii Outer Case Replacement: step 10, image 1 of 1
    • Use a metal spudger to remove the three highlighted screw covers stuck to the side of the Wii.
  11. Nintendo Wii Outer Case Replacement: step 11, image 1 of 1
    • Remove the following screws:
    • Two 5 mm Phillips screws
    • One 8.2 mm Tri-Wing screw
  12. Nintendo Wii Outer Case Replacement: step 12, image 1 of 1
    • Use a metal spudger to remove the two rubber feet stuck to the bottom face of the Wii near the rear ports.
  13. Nintendo Wii Outer Case Replacement: step 13, image 1 of 1
    • Remove the two 8.2 mm Tri-Wing screws hidden under the feet you just removed.
    • You may use a 4 mm hex driver to extend your bit into the recesses and reach the screws.
  14. Nintendo Wii Outer Case Replacement: step 14, image 1 of 1
    • Lift the outer case straight up off the body of the Wii.
Past 24 Hours: 13
Past 7 Days: 92
Past 30 Days: 396
All Time: 45,684
