Xbox 360 Faceplate Replacement
Views: 35K
View statistics:
Past 24 Hours:
7
Past 7 Days:
74
Past 30 Days:
270
All Time:
34,779
Comments: 4
2 comments on steps, 2 guide comments.
Go to guide comments
Completed: 85
85 people have marked this guide "completed." Will you be next?
Favorites: 21
21 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 minute
Difficulty: Very easy
Introduction
Go to step 1 ↓
Customize your Xbox 360 by adding a jazzy new faceplate.
Parts
  • Xbox 360 Faceplate
    View
Tools
  • Spudger
    4.9
    1. Xbox 360 Faceplate Replacement, Faceplate: step 1, image 1 of 3 Xbox 360 Faceplate Replacement, Faceplate: step 1, image 2 of 3 Xbox 360 Faceplate Replacement, Faceplate: step 1, image 3 of 3
      • Orient the console horizontally with the I/O ports side down.
      • Insert the edge of a spudger between the faceplate and the outer casing near the power button.
      • Run your spudger along the edge of the faceplate to release the clips securing it to the front of the Xbox.
      • Remove the faceplate from the front face of the console.
      Ask FixBot
85 other people completed this guide.
2 Guide Comments
Ok so my drive wasn't opening and i eventually came to the conclusion the drive was bad but i was wrong while replacing the drive the original one was plugged into the computer to obtain the drive key and it opened and closed fine, the problem is the case ...when i have the drive plugged into the xbox and tge actual xbox case is off it works once i put the case on it squishes the drive and it won't open, nothing appears wrong with any component. Help from anyone is appreciated
Societyburning - Reply Share
You don’t have to have tools for this.
brockchristian93 - Reply Share
Past 24 Hours: 7
Past 7 Days: 74
Past 30 Days: 270
All Time: 34,779
