Installing Nintendo Wii Heat Sink
  1. Installing Nintendo Wii Heat Sink, Faceplate: step 1, image 1 of 2 Installing Nintendo Wii Heat Sink, Faceplate: step 1, image 2 of 2
    • Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
  2. Installing Nintendo Wii Heat Sink: step 2, image 1 of 1
    • Remove the two 8.3 mm Tri-Point screws hidden under the covers you just removed.
  3. Installing Nintendo Wii Heat Sink: step 3, image 1 of 1
    • Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
  4. Installing Nintendo Wii Heat Sink: step 4, image 1 of 1
    • Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
  5. Installing Nintendo Wii Heat Sink: step 5, image 1 of 1
    • Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
  6. Installing Nintendo Wii Heat Sink: step 6, image 1 of 2 Installing Nintendo Wii Heat Sink: step 6, image 2 of 2
    • Carefully pull the faceplate away from the front of the Wii.
    • Use a pair of tweezers to disconnect the LED cable's plastic connector from the motherboard.
    • Remove the faceplate.
  7. Installing Nintendo Wii Heat Sink, Outer Case: step 7, image 1 of 3 Installing Nintendo Wii Heat Sink, Outer Case: step 7, image 2 of 3 Installing Nintendo Wii Heat Sink, Outer Case: step 7, image 3 of 3
    • Open the controller port cover until it is perpendicular to the black controller port bezel.
    • Pull the controller port cover straight up to release it from the outer case.
    • Repeat this procedure for the memory card port cover.
  8. Installing Nintendo Wii Heat Sink: step 8, image 1 of 2 Installing Nintendo Wii Heat Sink: step 8, image 2 of 2
    • Remove the two remaining 4.1 mm Phillips screws along the top edge of the black plastic controller port bezel.
    • Lift the bezel from the long edge furthest away from the controller ports and remove it from the Wii.
  9. Installing Nintendo Wii Heat Sink: step 9, image 1 of 1
    • Remove the two 5 mm Phillips screws above the controller ports.
  10. Installing Nintendo Wii Heat Sink: step 10, image 1 of 1
    • Use a metal spudger to remove the three highlighted screw covers stuck to the side of the Wii.
  11. Installing Nintendo Wii Heat Sink: step 11, image 1 of 1
    • Remove the following screws:
    • Two 5 mm Phillips screws
    • One 8.2 mm Tri-Point screw
  12. Installing Nintendo Wii Heat Sink: step 12, image 1 of 1
    • Use a metal spudger to remove the two rubber feet stuck to the bottom face of the Wii near the rear ports.
  13. Installing Nintendo Wii Heat Sink: step 13, image 1 of 1
    • Remove the two 8.2 mm Tri-Point screws hidden under the feet you just removed.
    • You may use a 4 mm hex driver to extend your bit into the recesses and reach the screws.
  14. Installing Nintendo Wii Heat Sink: step 14, image 1 of 1
    • Lift the outer case straight up off the body of the Wii.
  15. Installing Nintendo Wii Heat Sink, DVD Drive: step 15, image 1 of 2 Installing Nintendo Wii Heat Sink, DVD Drive: step 15, image 2 of 2
    • Remove the small Phillips screw securing the battery door to the bottom panel.
    • This screw is captive to the battery door.
    • Pull the battery door out of the Wii.
    • The system time will be reset once you remove the battery door.
    • This is a good time to change the CR2032 battery if it hasn't been changed recently.
  16. Installing Nintendo Wii Heat Sink: step 16, image 1 of 1
    • Remove the 8.2 mm Tri-Point screw that was hidden beneath the battery door.
  17. Installing Nintendo Wii Heat Sink: step 17, image 1 of 1
    • Remove the two 8.2 mm Tri-Point screws securing the DVD drive shield near the controller ports.
  18. Installing Nintendo Wii Heat Sink: step 18, image 1 of 1
    • Lift the DVD drive shield upward and remove it from the Wii.
  19. Installing Nintendo Wii Heat Sink: step 19, image 1 of 1
    • Remove the four 9 mm #1 Phillips screws securing the DVD drive to the bottom panel.
  20. Installing Nintendo Wii Heat Sink: step 20, image 1 of 1
    • Lift the side of the DVD drive opposite the controller ports enough to access the cables on its bottom face.
    • Carefully pull the DVD drive power cable out from under the plastic shroud near the heat sink.
  21. Installing Nintendo Wii Heat Sink: step 21, image 1 of 1
    • Pull the DVD drive power cable away from its socket on the DVD drive.
  22. Installing Nintendo Wii Heat Sink: step 22, image 1 of 2 Installing Nintendo Wii Heat Sink: step 22, image 2 of 2
    • Use your fingernail to flip up the retaining flap on the DVD drive ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the DVD drive ribbon cable out of its socket.
    • Remove the DVD drive from the Wii.
  23. Installing Nintendo Wii Heat Sink, Motherboard Cover: step 23, image 1 of 1
    • Use a pair of tweezers to lift the fan connector up and out of its socket on the logic board.
    • Be sure your tweezers are clamped down on the fan connector, not the socket on the motherboard.
  24. Installing Nintendo Wii Heat Sink: step 24, image 1 of 2 Installing Nintendo Wii Heat Sink: step 24, image 2 of 2
    • Remove the two 10 mm Phillips screws securing the fan to the fan shroud.
    • Remove the fan from the Wii.
  25. Installing Nintendo Wii Heat Sink: step 25, image 1 of 2 Installing Nintendo Wii Heat Sink: step 25, image 2 of 2
    • Use the tip of a spudger or another fine-pointed tool to carefully pry one of the black plastic retaining fingers attached to the fan shroud away from the Wi-Fi antenna board.
    • Lift the Wi-Fi antenna out of the fan shroud.
  26. Installing Nintendo Wii Heat Sink: step 26, image 1 of 1
    • Remove the single 10 mm Phillips screw securing the second Wi-Fi antenna to the top of the fan shroud.
  27. Installing Nintendo Wii Heat Sink: step 27, image 1 of 1
    • Remove the two pieces of tape securing the second Wi-Fi antenna cable to the plastic bracket near the heat sink.
  28. Installing Nintendo Wii Heat Sink: step 28, image 1 of 1
    • Carefully de-route both antennas from the frame of the Wii and lay them aside.
  29. Installing Nintendo Wii Heat Sink: step 29, image 1 of 2 Installing Nintendo Wii Heat Sink: step 29, image 2 of 2
    • Remove the three 10 mm Phillips screws securing the fan shroud to the Wii.
    • Lift the fan shroud off the heat sink and remove it from the Wii.
  30. Installing Nintendo Wii Heat Sink: step 30, image 1 of 3 Installing Nintendo Wii Heat Sink: step 30, image 2 of 3 Installing Nintendo Wii Heat Sink: step 30, image 3 of 3
    • Remove the following six screws securing the EMI fingers to the bottom panel:
    • Four 7 mm Phillips screws
    • Two 11.3 mm Phillips screws
    • Remove both sets of EMI fingers from the Wii.
  31. Installing Nintendo Wii Heat Sink: step 31, image 1 of 2 Installing Nintendo Wii Heat Sink: step 31, image 2 of 2
    • Remove the following three screws:
    • One 7 mm Phillips screw
    • Two 10 mm Phillips screws
    • Lift the bracket out of the Wii.
  32. Installing Nintendo Wii Heat Sink: step 32, image 1 of 3 Installing Nintendo Wii Heat Sink: step 32, image 2 of 3 Installing Nintendo Wii Heat Sink: step 32, image 3 of 3
    • Remove the three 10 mm Phillips screws securing the black bracket to the bottom panel near the front of the Wii.
    • Slightly lift the bracket and use your other hand to pull the retaining clip away from where the Wi-Fi antennas enter the motherboard sheild.
    • Remove the bracket from the Wii.
    • Be sure not to lose the small square nut loosely held by the black plastic bracket.
  33. Installing Nintendo Wii Heat Sink: step 33, image 1 of 1
    • Remove the nine remaining 7 mm Phillips screws securing the motherboard cover to the bottom panel.
  34. Installing Nintendo Wii Heat Sink: step 34, image 1 of 1
    • Carefully lift the motherboard cover off the motherboard, minding any cables that may get caught.
    • On some models, a thermal pad for the wireless chip is attached to the underside of the motherboard cover. Be sure to replace it when reassembling.
  35. Installing Nintendo Wii Heat Sink, Heat Sink: step 35, image 1 of 1
    • Remove the four 11.3 mm Phillips screws securing the heat sink to the bottom panel.
  36. Installing Nintendo Wii Heat Sink: step 36, image 1 of 1
    • Lift the heat sink off the motherboard.
    • When working near the exposed processors, be sure not to disturb the thermal pads as the thermal paste may leak out.
Past 24 Hours: 11
Past 7 Days: 85
Past 30 Days: 319
All Time: 25,921
