Introduction
Use this guide to replace a worn-out fan.
Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
Open the controller port cover until it is perpendicular to the black controller port bezel.
Pull the controller port cover straight up to release it from the outer case.
Remove the two remaining 4.1 mm Phillips screws along the top edge of the black plastic controller port bezel.
Lift the bezel from the long edge furthest away from the controller ports and remove it from the Wii.
Use a metal spudger to remove the three highlighted screw covers stuck to the side of the Wii.
Use a metal spudger to remove the two rubber feet stuck to the bottom face of the Wii near the rear ports.
Grab the fan connector with a pair of tweezers and lift it straight up and out of its socket on the motherboard.
