Installing Nintendo Wii Faceplate
  1. Installing Nintendo Wii Faceplate, Faceplate: step 1, image 1 of 2 Installing Nintendo Wii Faceplate, Faceplate: step 1, image 2 of 2
    • Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
  2. Installing Nintendo Wii Faceplate: step 2, image 1 of 1
    • Remove the two 8.3 mm Tri-Wing screws hidden under the covers you just removed.
  3. Installing Nintendo Wii Faceplate: step 3, image 1 of 1
    • Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
  4. Installing Nintendo Wii Faceplate: step 4, image 1 of 1
    • Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
  5. Installing Nintendo Wii Faceplate: step 5, image 1 of 1
    • Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
  6. Installing Nintendo Wii Faceplate: step 6, image 1 of 2 Installing Nintendo Wii Faceplate: step 6, image 2 of 2
    • Carefully pull the faceplate away from the front of the Wii.
    • Use a pair of tweezers to disconnect the LED cable's plastic connector from the motherboard.
    • Remove the faceplate.
Past 24 Hours: 10
Past 7 Days: 91
Past 30 Days: 333
All Time: 53,485
