Shop the Holiday Gift Guide
Nintendo Switch Rear Panel Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
Past 30 Days:
13
All Time:
311
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 30 minutes
Difficulty: Easy
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Introduction
Go to step 1 ↓
Follow this guide to remove the rear panel from a Nintendo Switch.
A single screw is hidden underneath the kickstand.
Parts
Tools
    1. Nintendo Switch Rear Panel Replacement, Rear Panel: step 1, image 1 of 1
      • Remove the four 6.3 mm Tri-point Y00 screws from the rear panel.
      Ask FixBot
    2. Nintendo Switch Rear Panel Replacement: step 2, image 1 of 1
      • Remove the single 6.1 mm Phillips #000 screw from underneath the kickstand.
      Ask FixBot
    3. Nintendo Switch Rear Panel Replacement: step 3, image 1 of 1
      • Remove the two 2.7 mm Phillips #000 screws from the bottom of the device.
      Ask FixBot
    4. Nintendo Switch Rear Panel Replacement: step 4, image 1 of 1
      • Remove the single 2.7 mm Phillips #000 screw from the top of the device.
      Ask FixBot
    5. Nintendo Switch Rear Panel Replacement: step 5, image 1 of 2 Nintendo Switch Rear Panel Replacement: step 5, image 2 of 2
      • Remove the single 3.8 mm Phillips #000 screw from the right Joy-Con rail.
      • Remove the single 3.8 mm Phillips #000 screw from the left Joy-Con rail.
      Ask FixBot
    6. Nintendo Switch Rear Panel Replacement: step 6, image 1 of 3 Nintendo Switch Rear Panel Replacement: step 6, image 2 of 3 Nintendo Switch Rear Panel Replacement: step 6, image 3 of 3
      • Pull the rear panel up and off of the device.
      Ask FixBot
Author
with
Blake Klein
75,542 Reputation
49 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 311
