Ryobi RJ1861V Motor Housing Replacement
  1. Ryobi RJ1861V Motor Housing Replacement, Trigger Assembly: step 1, image 1 of 1
    • Use a Torx T20 screwdriver to remove the nine 16.5 mm screws around the trigger assembly.
  2. Ryobi RJ1861V Motor Housing Replacement: step 2, image 1 of 2 Ryobi RJ1861V Motor Housing Replacement: step 2, image 2 of 2
    • Use a Torx T20 screwdriver to remove the two 16.5 mm screws near the trigger.
  3. Ryobi RJ1861V Motor Housing Replacement, Motor Housing: step 3, image 1 of 1
    • Use a Torx T20 bit or screwdriver to remove the six 19 mm screws securing the gear case cover.
  4. Ryobi RJ1861V Motor Housing Replacement: step 4, image 1 of 2 Ryobi RJ1861V Motor Housing Replacement: step 4, image 2 of 2
    • Use a Phillips #2 bit or screwdriver to remove the four 37 mm screws from the top and the bottom of the gear case.
    • Once these 4 screws are removed, you have access to the motor assembly.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 254
