Jam Voice Rubber Base Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
60
All Time:
546
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 - 3 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
The rubber base may be worn and in need of replacement or to gain access to the underside of the device . Depending on objectives, a new rubber base may be applied or the used base may be reapplied.
Tools
    1. Jam Voice Rubber Base Replacement, Rubber Base: step 1, image 1 of 1
      • Turn the speaker upside down, as shown .
      • When reassembling your device, place the same or a new rubber pad on the bottom of the device using the perpendicular rubber protrusions as a guide for placement.
      Ask FixBot
    2. Jam Voice Rubber Base Replacement: step 2, image 1 of 2 Jam Voice Rubber Base Replacement: step 2, image 2 of 2
      • Use the plastic opening tool to help peel the rubber cover off the base.
      • Peel off the rest of the rubber base by hand.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 60
All Time: 546
