Shop the Holiday Gift Guide
Nintendo Switch Micro SD Card Reader Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
4
Past 30 Days:
14
All Time:
101
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes - 1 hour
Difficulty: Easy
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Introduction
Go to step 1 ↓
Follow this guide to replace the micro SD card board in a Nintendo Switch gaming console.
WARNING: the battery won’t be disconnected for this repair so be cautious when using metal tools around the motherboard.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Nintendo Switch Micro SD Card Reader Replacement, Micro SD Card Reader: step 1, image 1 of 1
      • Remove the single 3.1 mm Phillips screw from micro SD card board.
      Ask FixBot
    2. Nintendo Switch Micro SD Card Reader Replacement: step 2, image 1 of 2 Nintendo Switch Micro SD Card Reader Replacement: step 2, image 2 of 2
      • Gently lift the micro SD card board straight up, away from the Switch to disconnect and remove it.
      • During reassembly, line up the micro SD card board and lightly press on the foam pad until the press connector snaps into place to reconnect it.
      Ask FixBot
Author
with
Blake Klein
75,542 Reputation
49 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 14
All Time: 101
