Lenovo Chromebook 300e Daughter Board Replacement
      • Check out other guides for removal of the keyboard for Lenovo N23/N21 Chromebooks.
      • Remove the screws from the bottom of the Chromebook.
      • On a clean surface, fold the Chromebook screen over to the back to remove the keyboard.
      • Using a Jimmy remove the keyboard starting at the top of the keyboard.
      • When the entire keyboard has been popped up lift the keyboard from the end opposite the trackpad and carefully disconnect the trackpad and keyboard ribbon cables.
      • Flip over the keyboard so that the keys side is down and place it to the side of your workspace.
      • Check that the thermal pad is still stuck to either the keyboard or the motherboard.
      Ask FixBot
      • Power off the computer by holding down the power button for a few seconds.
      • Disconnect the battery
      • Remove the ribbon cable connecting the Daughter and Motherboard from the motherboard side first.
      • Remove the ribbon cable from the daughter board.
      • Remove the four screws to release the motherboard.
      • Disconnect the speaker wire from the daughterboard.
      • Remove the daughterboard from the Chromebook.
      Ask FixBot
      • Place the new daughterboard in the chromebook.
      • Plug in the speakers to the daughterboard.
      • Screw the daughterboard into place.
      • Connect the ribbon cable, first to the daughterboard and then to the motherboard.
      Ask FixBot
Nathan King
353 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 53
All Time: 1,062
