Nintendo Switch Left Joy-Con Shell Replacement
  1. Nintendo Switch Left Joy-Con Shell Replacement, Opening the controller (1/3): step 1, image 1 of 2 Nintendo Switch Left Joy-Con Shell Replacement, Opening the controller (1/3): step 1, image 2 of 2
    • Start by unscrewing the four Tri-wing Y00 screws from the back panel.
    • Keep the screws somewhere safe and organized.
    Ask FixBot
  2. Nintendo Switch Left Joy-Con Shell Replacement, Opening the controller (2/3): step 2, image 1 of 3 Nintendo Switch Left Joy-Con Shell Replacement, Opening the controller (2/3): step 2, image 2 of 3 Nintendo Switch Left Joy-Con Shell Replacement, Opening the controller (2/3): step 2, image 3 of 3
    • Insert an opening pick into the seam at the bottom edge of the controller (opposite the L and ZL buttons).
    • Slowly slide the flat edge of your opening pick up the side of the Joy-Con, opposite from the rail.
    Ask FixBot
  3. Nintendo Switch Left Joy-Con Shell Replacement, Opening the controller (3/3): step 3, image 1 of 2 Nintendo Switch Left Joy-Con Shell Replacement, Opening the controller (3/3): step 3, image 2 of 2
    • With the charging rail facing away from you, open the Joy-Con like a laptop.
    • Do not fully remove the back panel yet; there are still two ribbon cables connecting the charging rail to the motherboard.
    Ask FixBot
  4. Nintendo Switch Left Joy-Con Shell Replacement, Disconnecting the battery: step 4, image 1 of 1
    • Gently pry the battery connector straight up from its socket on the motherboard using a plastic spudger (avoid metal ones to reduce the risk of shorting components). This will keep the Joy-Con from powering on during the repair.
    • Use caution while working around the rumble module's cable which runs in the vicinity of the battery connector.
    • When handling electronics and/or batteries, it's a good idea to wear at least an anti-static bracelet.
    Ask FixBot
  5. Nintendo Switch Left Joy-Con Shell Replacement, Removing the battery: step 5, image 1 of 2 Nintendo Switch Left Joy-Con Shell Replacement, Removing the battery: step 5, image 2 of 2
    • Insert a spudger between the battery and the Joy-Con housing.
    • Gently pry out the battery.
    • The battery is lightly taped in place.
    • Be careful not to deform, puncture, or damage the battery.
    Ask FixBot
  6. Nintendo Switch Left Joy-Con Shell Replacement, Removing the battery housing: step 6, image 1 of 1
    • Remove the three 3½mm golden Phillips #00 screws from the mid-frame.
    Ask FixBot
  7. Nintendo Switch Left Joy-Con Shell Replacement, Accessing the controller's motherboard: step 7, image 1 of 1
    • Carefully flip the mid-frame over, away from the motherboard, as if you were turning the page of a book.
    • The flex cables are extremely fragile. It is advised to use non-sharp tweezers rather than bare hands.
    Ask FixBot
  8. Nintendo Switch Left Joy-Con Shell Replacement, Disconnecting the ribbon cables: step 8, image 1 of 2 Nintendo Switch Left Joy-Con Shell Replacement, Disconnecting the ribbon cables: step 8, image 2 of 2
    • Use tweezers to flip the ZIF connector lock opposite the cable.
    • The ZL button is locked in place by a small ZIF connector on the motherboard.
    • Use tweezers to gently pull the ZL button flex cable out of its ZIF connector socket. The mid-frame is now disconnected and can be removed.
    Ask FixBot
  9. Nintendo Switch Left Joy-Con Shell Replacement, Removing the L button: step 9, image 1 of 2 Nintendo Switch Left Joy-Con Shell Replacement, Removing the L button: step 9, image 2 of 2
    • Unlock the rail's top ZIF connector and then disconnect the cable.
    • Unlock the rail's bottom ZIF connector and disconnect the cable. You can now remove the rail from the back frame.
    • Remove the L button and its spring.
    • Be careful because the spring tends to fling away.
    Ask FixBot
  10. Nintendo Switch Left Joy-Con Shell Replacement, Removing the rail: step 10, image 1 of 3 Nintendo Switch Left Joy-Con Shell Replacement, Removing the rail: step 10, image 2 of 3 Nintendo Switch Left Joy-Con Shell Replacement, Removing the rail: step 10, image 3 of 3
    • Remove the screw holding the rail in place. Remove the rail from the back frame and set it off to the side.
    Ask FixBot
  11. Nintendo Switch Left Joy-Con Shell Replacement, Removing the latch button: step 11, image 1 of 1
    • Remove the latch button and set it off to the side.
    Ask FixBot
  12. Nintendo Switch Left Joy-Con Shell Replacement, Removing the triggers 1/2: step 12, image 1 of 2 Nintendo Switch Left Joy-Con Shell Replacement, Removing the triggers 1/2: step 12, image 2 of 2
    • Depress the latch underneath the trigger using tweezers. Gently pry the trigger off.
    • Make sure to note the position of the two springs under the trigger as they will need to go back in the same spot on the new mid-frame.
    Ask FixBot
  13. Nintendo Switch Left Joy-Con Shell Replacement, Removing the triggers 2/2: step 13, image 1 of 2 Nintendo Switch Left Joy-Con Shell Replacement, Removing the triggers 2/2: step 13, image 2 of 2
    • Remove the screw holding the circuit board for the trigger in place.
    • Remove the circuit board.
    Ask FixBot
  14. Nintendo Switch Left Joy-Con Shell Replacement, Removing the joystick 1/2: step 14, image 1 of 2 Nintendo Switch Left Joy-Con Shell Replacement, Removing the joystick 1/2: step 14, image 2 of 2
    • Remove the screws holding the analog stick in place.
    • The top-left screw is covered by the L button's flex cable.
    • Unlock the ZIF connector and remove the flex cable using tweezers.
    Ask FixBot
  15. Nintendo Switch Left Joy-Con Shell Replacement, Removing the joystick 2/2: step 15, image 1 of 2 Nintendo Switch Left Joy-Con Shell Replacement, Removing the joystick 2/2: step 15, image 2 of 2
    • Remove the analog stick.
    Ask FixBot
  16. Nintendo Switch Left Joy-Con Shell Replacement, Removing the top flex circuit: step 16, image 1 of 3 Nintendo Switch Left Joy-Con Shell Replacement, Removing the top flex circuit: step 16, image 2 of 3 Nintendo Switch Left Joy-Con Shell Replacement, Removing the top flex circuit: step 16, image 3 of 3
    • Remove the screws holding the flex circuit (marked by a red circle) for the minus and L buttons.
    • Remove the flex circuit.
    Ask FixBot
  17. Nintendo Switch Left Joy-Con Shell Replacement, Removing the minus button: step 17, image 1 of 1
    • Remove the minus button.
    • There will be a silicone membrane covering the minus button. Make sure to put it back over the minus button during reassembly.
    Ask FixBot
  18. Nintendo Switch Left Joy-Con Shell Replacement, Removing the motherboard 3/3: step 18, image 1 of 1
    • Remove the screws holding the motherboard in place.
    Ask FixBot
  19. Nintendo Switch Left Joy-Con Shell Replacement, Removing the rumble pack: step 19, image 1 of 3 Nintendo Switch Left Joy-Con Shell Replacement, Removing the rumble pack: step 19, image 2 of 3 Nintendo Switch Left Joy-Con Shell Replacement, Removing the rumble pack: step 19, image 3 of 3
    • Using a spudger, gently pry the rumble module out of its housing.
    • Remove the rumble module and the motherboard.
    Ask FixBot
  20. Nintendo Switch Left Joy-Con Shell Replacement, Removing the remaining buttons: step 20, image 1 of 1
    • Remove the remaining five buttons from the shell.
    Ask FixBot
96 other people completed this guide.
12 Guide Comments
This guide was very helpful! A picture of the latch location on the trigger (step 12) would have been a big help, that step took a minute because I was putting pressure on the wrong spot.
I also noticed that most of the #00 screws were more receptive to a J00 bit. Might be worth noting in the tools section since swapping between them can strip a screw.
Fitz Montville - Reply Share
Used this guide for reference on the tools needed, someone else pointed out to use the J00 bit instead of the P00 and I’ll second that as the fit for the screws was much better, thanks for the guide much appreciated!
Lee Whittaker - Reply Share
Exactly what I needed! Dropped a set of controllers on a tile flow and the rail popped out and pulled the ribbon cables too. I picked up another iFixit toolkit with some J bits to put it back together. I don’t know why I waited this long to fix it. Charged the controllers overnight and I’m up another set now!
energy96 - Reply Share
Others above have mentioned that they needed to use a J00 bit instead of P00, but mine did not work with a J00 and was better with a P000
Jeremy Johnson - Reply Share
Small thing. In the tools list, it incorrectly says Y0 while the rest of the post correctly says Y00 for the back screws.
William Doering - Reply Share
Past 24 Hours: 57
Past 7 Days: 289
Past 30 Days: 1,305
All Time: 111,831
