Introduction
I decided to create this guide because i got *triggerred* trying to reassemble the PS4 Dualshock 4 Controller
Remove these two triggers and springs from the backplate.
Find which trigger goes on which side and put the springs in the trigger part facing towards the inside of the controller.
On these two clips...
Push down the trigger until it clicks on both sides.
Connect the light bar cable using your fingers. Make sure it is fully pushed down and that is plugged in the right way.
close the cover starting from the side of the triggers. Don't worry if it's a bit hard to do so, but be careful so you don't break the plastic between the trigger and the bumper.
Push down until it clicks everywhere.
Finally, screw in these four screws using a PH0 screwdriver.
27 other people completed this guide.
4 Guide Comments
This guide is wrong. The top part spring should be inside the trigger, if you look at the other trigger it’s not exposed.
@angusyung Like you say, swivel one end of the spring into the buttons' cavity and as you line up the placement of the L2/R2 button into the Red marked clips, focus on getting the other end of the spring into the Cyan marked Rail.
