Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tool used on this step:Adhesive Cleanup Kit (Set of 12)$7.99
Use the point of a spudger to scrape off any adhesive left on the frame.
Apply a bit of isopropyl alcohol to a cotton swab or lint-free cloth and clean the frame until it's free of adhesive residue.
Tool used on this step:Tesa 61395 Tape$2.95
Use your fingers to install strips of thin, double-sided tape to the raised lip along the edges of the frame. Use 1Â mm strips for the top and bottom edges and 2Â mm strips for the sides.
Align the screen's cable with its cutout in the frame.
Route the cable through its cutout, ensuring it reaches its connector on the board.
Align the right edge of the screen with its recess in the frame.
Press the right edge of the screen into place, then work your way to the left edge until the entire screen is adhered to the frame.
Use tweezers or your fingers to slide the screen cable into its ZIF connector until it's fully seated.
Flip the hinged locking flap down to secure the cable.
