Nintendo Switch 2 Kickstand Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Nintendo Switch 2 Kickstand Removal, Remove the upper hinge covers: step 1, image 1 of 2 Nintendo Switch 2 Kickstand Removal, Remove the upper hinge covers: step 1, image 2 of 2
      • Use the flat end of a spudger to pry up one of the hinge's plastic upper hinge covers until it "pops" up.
      Ask FixBot
    2. Nintendo Switch 2 Kickstand Removal: step 2, image 1 of 2 Nintendo Switch 2 Kickstand Removal: step 2, image 2 of 2
      • Pull the upper hinge cover out from underneath the lower hinge cover to remove it.
      • The cover is clipped in place and requires a little bit of force to remove.
      Ask FixBot
    3. Nintendo Switch 2 Kickstand Removal: step 3, image 1 of 3 Nintendo Switch 2 Kickstand Removal: step 3, image 2 of 3 Nintendo Switch 2 Kickstand Removal: step 3, image 3 of 3
      • Repeat this process to remove the upper hinge cover on the other hinge.
      Ask FixBot
    4. Nintendo Switch 2 Kickstand Removal, Remove the kickstand screws: step 4, image 1 of 2 Nintendo Switch 2 Kickstand Removal, Remove the kickstand screws: step 4, image 2 of 2
      • Use a JIS 00 driver to remove the two 2.3 mm‑long silver screws securing each hinge to the inside of the back cover (four total).
      Ask FixBot
    5. Nintendo Switch 2 Kickstand Removal, Remove the kickstand: step 5, image 1 of 3 Nintendo Switch 2 Kickstand Removal, Remove the kickstand: step 5, image 2 of 3 Nintendo Switch 2 Kickstand Removal, Remove the kickstand: step 5, image 3 of 3
      • Open the kickstand to a 45‑degree angle and pull it out of the back cover to remove it.
      Ask FixBot
Nick Schultz
65,446 Reputation
343 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 9
All Time: 106
