Nintendo Switch 2 Fan Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Nintendo Switch 2 Fan Removal, Disconnect the fan: step 1, image 1 of 2 Nintendo Switch 2 Fan Removal, Disconnect the fan: step 1, image 2 of 2
      • Use the point of a spudger to flip up the locking flap on the fan cable ZIF connector, located next to the fan on the console's board.
      Ask FixBot
    2. Nintendo Switch 2 Fan Removal: step 2, image 1 of 3 Nintendo Switch 2 Fan Removal: step 2, image 2 of 3 Nintendo Switch 2 Fan Removal: step 2, image 3 of 3
      • Use tweezers or your fingers to gently pull the cable out of its socket.
      • If you're using tweezers, pull the cable out by its "wings" instead of gripping the cable itself.
      Ask FixBot
    3. Nintendo Switch 2 Fan Removal, Remove the fan screws: step 3, image 1 of 2 Nintendo Switch 2 Fan Removal, Remove the fan screws: step 3, image 2 of 2
      • Use a JIS 00 driver to remove the three 5.2 mm‑long silver screws securing the fan.
      Ask FixBot
    4. Nintendo Switch 2 Fan Removal, Remove the fan: step 4, image 1 of 3 Nintendo Switch 2 Fan Removal, Remove the fan: step 4, image 2 of 3 Nintendo Switch 2 Fan Removal, Remove the fan: step 4, image 3 of 3
      • Slide the fan out of its recess to free its cable, then pick it up to remove it.
      Ask FixBot
Nick Schultz
65,491 Reputation
343 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 13
All Time: 125
