Introduction
Go to step 1 ↓If your Rienok S1 Mini Speaker has any battery damage, or to access the internals of the device, follow these step by step instructions to access the battery.
The battery is the component that gives the speaker energy to work. It’s an important part for the overall life of the speaker, and a good battery gives you an optimal experience.
Before beginning, make sure the power is off.
Tools
Start with the buttons panel up and facing you.
Wedge in one iFixit opening pick, and apply outward pressure to pop out one side of the grille.
Using a second pick, slide from the first pick towards the opposite end until one whole side is popped out.
Wedge an iFixit opening pick into the space between the ring and the housing.
Insert a Jimmy into the gap created.
Apply an out-and-upward pressure with the Jimmy to disconnect the plastic clips surrounding the ring.
Work the Jimmy around the ring, disconnecting the clips along the way until they are all disconnected.
Hold the device with the speakers facing up.
Remove the six 10 mm silver screws connecting the two halves of the case with a Phillips #1 screwdriver.
Insert a Jimmy into the seam between both halves.
Lightly twist the Jimmy until a small gap appears.
Work the Jimmy across the length creating and widening the gap as you go across.
With the gap across the whole length, grasp both halves and lightly pull apart.
DO NOT yank apart; the two halves are still connected by a few cords.
Gently grasp the battery and slowly and carefully remove it.
Remove the foam glue, and unplug the battery to disconnect it.
2 Guide Comments
I used this to take mine apart but this isn't my problem. Where the charging cable plugs in, that came lose. I can't put it back so I will take it by my local tech college and see if they will fix it for me.
Any information about the kid of battery this use, and if there are suitable, replacement parts that would work with this ?
