Ryobi P411 Pad Assembly Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
77
All Time:
455
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this guide to replace the pad assembly on your Ryobi P411. The pad of the sander is what is interfacing with the work surface. Because of this, it can often end up damaged. In order to replace any part of the Ryobi P411, use this replacement guide first. Make sure to remove the battery before you begin.
Tools
    1. Ryobi P411 Pad Assembly Replacement, Pad Assembly: step 1, image 1 of 3 Ryobi P411 Pad Assembly Replacement, Pad Assembly: step 1, image 2 of 3 Ryobi P411 Pad Assembly Replacement, Pad Assembly: step 1, image 3 of 3
      • Remove the sanding pad to expose the screws at the bottom of the sander.
      Ask FixBot
    2. Ryobi P411 Pad Assembly Replacement: step 2, image 1 of 3 Ryobi P411 Pad Assembly Replacement: step 2, image 2 of 3 Ryobi P411 Pad Assembly Replacement: step 2, image 3 of 3
      • Remove the four M5 x 8.9mm screws with a T6 Torx screwdriver.
      • Remove the pad assembly.
      Ask FixBot
Paula Meier
769 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 77
All Time: 455
